97Sandbox
- February 7, 2019
- Seward, NE
- 2000 Explorer Sport
One thing I would to address before I start the drivetrain swap is the hard starting my Mounty has developed. Ironically the condition has been become more noticable after replacing fuel pump. It actually use to fire right up in 1-3 cranks.
When I start the Mounty, it takes about 8-12 cranks before the engine starts. However, as soon as it starts, it runs great (no stumbling, stalling, etc.).
It has a new fuel filter and pump and I've verified 65psi at idle. I cleaned the injectors (cycle on and spray carb cleaner through) before reinstalling them with new o-rings during the engine refresh. So I don't think the issue is fuel.
The air filter is new and the air intake, TB, and MAF have all been cleaned. So it shouldn't be an air issue.
I pulled a plug on each bank (plugs are new, Motorcraft and I checked gaps before installing) and they both looked normal. Plug wires are new and well protected. So spark seems like it wouldn't be an issue unless it's a sensor, PCM, or coil pack problem. But I'd think one of those would make the truck run rough after starting.
Battery seems okay, has no trouble cranking the starter over and over and over while I try to start the engine.
Where else should I look?
