2008 Explorer XLT Cloth to Leather seat swap out
okok2727
2008 Explorer XLT
I purchased an 08 Explorer XLT with damaged rear 40/60 2nd row seat missing 40 2nd row seat and damaged drivers side seat. I was able to find leather full set of seats. The fronts seem easy enough to swap out and I was able to loosen the bolts without snapping off the heads.
The 2nd row leather is not as easy as they are fold down and up seats as the explorer they came out of had a 3rd row. The fold down leather have a plate that they mount to which mounts to the floor. I have searched and cannot find a diagram of how the plate mounts to the floor. I have found the matching holes but in some cases Ford uses studs & nuts instead of bolts into the floor.
Can someone snap a picture of their leather seat fold up/down seat plate installation so I can make sure I have the right bolts and studs/nut combinations? I really appreciate it as the closest dealer/used car place with an explorer is about an hour away.
If anyone has done this type of instillation/swap out before I would appreciate any tips/tricks/advice
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
Flag Gibby
Flagstaff, AZ
2006 Mountaineer AWD
okok2727
2008 Explorer XLT
Thanks Flag.
That is a great diagram and resource for Parts as well. I think I may have figured out that some of the holes in the floor are for bolt studs rather than bolts for the seat plate. Yes I have the easy entry seats. I have a ton of Bolts from the old seats and some from the junkyard but they have failed to give me the studs. They are about an hour and 15 away so its not an easy trek to go view where they are or grab them from them. If push comes to shove your diagram gives me a way to order the whole hardware kit and then I can figure out where the studs go vs the bolts. If anyone has a pic of their seats folded up so I can see which are bolt holes vs stud and nuts that would be great as well.
Really appreciate your time Flag and everyone else who read the post. I am almost there need to rewire the front seat connectors and finish the rear seat installation
MotorCityFats13
Flatrock MI
2007 Explorer XLT 4.0L
I can't see leather being different from cloth since ford would like to save money on hardware.... here are some pictures of my bolts and studs
2007 xlt 60/40 with 3rd row
I think I have every bolt/stud....
okok2727
2008 Explorer XLT
Thank you very much! This actually answers a bunch of questions. I am happy to see this since I think on my own I would have answered them differently. Thanks again for your time and in posting these.
I finished the installation and got alot of confidence from the diagrams from and the pictures. Leather seats look great now. I am not sure the front seat wiring is 100% ( Its not a 1 for 1 unfortunately) perfect but its functional. I will look for the leather vs cloth wiring schematics in a few but right now the family will enjoy the leather seats vs the ripped up and in some cases missing dog smelly seats that came with the car
X~FACTOR
Name is Ray
Valley Stream, Long Island
'97 XLT 4-dr SOHC
MotorCityFats13 :thumbsup:
O Dome Lights 2008 Explorer XLT Stock 2006 -2010 Explorers 1
B 2008 Ford Explorer XLT Won't Crank Stock 2006 -2010 Explorers 14
X 2008 Ford Explorer xlt Stock 2006 -2010 Explorers 4
P 2008 Ford Explorer XLT Stock 2006 -2010 Explorers 52
S Rough idle on my 2008 Ford Explorer XLT Stock 2006 -2010 Explorers 4
N 2008 Explorer XLT Stock 2006 -2010 Explorers 0
R 2008 Ford Explorer XLT v6 Stock 2006 -2010 Explorers 2
N 2008 Explorer XLT 4.6L V8 - Broken Sway Bar Link? Stock 2006 -2010 Explorers 8
P 2008 Explorer XLT 4WD Rocker Moulding Options Stock 2006 -2010 Explorers 1
T 2008 Explorer 4.0 V6 XLT battery problems Stock 2006 -2010 Explorers 3
M explorer 2008 xlt 4.0 unable to clear the codes. Stock 2006 -2010 Explorers 2
M Explorer 2008 XLT RPM Needle Goes Down and Vehicle Off Stock 2006 -2010 Explorers 3
N 2008 Ford Explorer xlt Air bag light Stock 2006 -2010 Explorers 1
W 2008 Explorer XLT Front Bumper Cover Replace Stock 2006 -2010 Explorers 2
B 2008 Explorer XLT blower motor resistor procedure Stock 2006 -2010 Explorers 26
F Explorer 2008 XLT 4.6L tyre change question Stock 2006 -2010 Explorers 8
J 2008 Explorer XLT 2WD 4.0 Stops Shifting Stock 2006 -2010 Explorers 1
R Explorer 2008 XLT transmission+AC problem Stock 2006 -2010 Explorers 0
M 2008 Explorer XLT - anyone have any problems? Stock 2006 -2010 Explorers 0
A 2008 Ford Explorer XLT 4x4 5 Spd Auto Stock 2006 -2010 Explorers 5
A 2008 Explorer - Car starts, drives but then won't start later but then starts again magically Stock 2006 -2010 Explorers 8
E Max Tire Size on 18" 2008 Explorer Limited. Stock 2006 -2010 Explorers 5
H 2008 Ford Explorer Check RSC now ABs Traction control and wrench on Stock 2006 -2010 Explorers 4
R 2008 Explorer middle dash bezel removal Stock 2006 -2010 Explorers 3
R 2008 Explorer hvac won’t go to floor setting Stock 2006 -2010 Explorers 1
B Explorer 2008 leaking hose Stock 2006 -2010 Explorers 4
D 2008 v8 Explorer 6R60 trans issues Stock 2006 -2010 Explorers 11
D 2008 Ford Explorer Wrench Symbol Stock 2006 -2010 Explorers 5
B 265/65-18 BFG All Terrain on stock 2008 Explorer Limited 4x4 Stock 2006 -2010 Explorers 9
L 16" rims on 2008 Explorer Stock 2006 -2010 Explorers 14
R 2008 Explorer 4x4 wearing inside of tires very quickly Stock 2006 -2010 Explorers 4
J Installed 5r55s week later not shifting right 2008 4.0 2wd Explorer Stock 2006 -2010 Explorers 8
R 2008 Explorer air will not go to floor vents under dash Stock 2006 -2010 Explorers 0
I Stalling 2008 Explorer Stock 2006 -2010 Explorers 4
S 2008 explorer 4.0 - DUBAI Stock 2006 -2010 Explorers 7
J 2008 Explorer 4WD-Latest year engine I can substitute? Stock 2006 -2010 Explorers 7
T 2008 Explorer 4wd Differential vent hose Stock 2006 -2010 Explorers 2
J 2008 ford Explorer bucking at 40 to 45 mph Stock 2006 -2010 Explorers 0
R 2008 Explorer door gasket/weather seals Stock 2006 -2010 Explorers 9
G 2008 Explorer -- Worried About Transmission. Any advice? Stock 2006 -2010 Explorers 13
D 2008 Mercury Mountaineer 4.6 AWD (Ford Explorer) Engine Replacement Stock 2006 -2010 Explorers 3
R 2008 Explorer pop/clack sound when shifting into reverse (video) Stock 2006 -2010 Explorers 4
N C1440 Error on my Ford Explorer 2008 Stock 2006 -2010 Explorers 0
X 2008 Explorer transfer case swap Stock 2006 -2010 Explorers 4
S 2008 Explorer Stalling 4.6l, 2WD Stock 2006 -2010 Explorers 9
R 2008 explorer stuck in 4x4 high? Stock 2006 -2010 Explorers 10
B 2008 Explorer 4.0L v6 p0302 and p0316 Stock 2006 -2010 Explorers 2
R 2008 explorer wont engage gears Stock 2006 -2010 Explorers 10
N 2008 ford explorer entry keypad not working Stock 2006 -2010 Explorers 0
J 2008 explorer no crank Stock 2006 -2010 Explorers 4
Similar threads
