mobius00
- March 24, 2019
- Poland
- 2016 Limited
Hi there all,
It is Ford Explorer 2016 limited, with the following settings:
Autolamps ON (rotary switch),
Daytime Lights - ON (check enabled) in the cluster's settings,
All doors closed,
Gearbox in Park,
Ignition ON,
Engine OFF.
Bunch of FORScan settings modified, can't recall anything to do with these LED lights though...
Ends up with only one LED signature light on
What is / could be the problem?
Mechanical / Electrical / FORScan settings?![Help :help: :help:](/forums/../forums.old/images/smilies/help.gif)
Upon turning on engine AND putting Drive / Reverse - both sides of the signature light are on OR when opening the doors - both sides light up.
Thanks a lot in advance for all the hints!
All doors closed,
Gearbox in Park,
Ignition ON,
Engine OFF.
