Explorer Forum Covers the Explorer ST, Explorer Sport, Explorer Sport Trac, Lincoln Aviator,
Mercury Mountaineer, Mazda Navajo, Ford Ranger, Mazda Pickups, and the Ford Aerostar
Register Today It's free!
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an alternative browser.
21Robbie21 SAS
- Thread starter 21robbie21
- Start date
Add an avatar, upload photo attachments, and more!.
- April 16, 2001
- Suwanee, GA
- '99 Sport 4x4
yeah but that's a wide track axle. It's a decent amount wider than the 8.8, around 5" I think. I guess some spacers would solve that, but they'd be pretty big spacers.
IZwack
Moderator Emeritus
- February 5, 2003
- Germantown, MD
- 1998 Ford Explorer
aha yeah, im running the same front axle as Robbie. i'm going with a wider 9" for the rear tho from an older f150.jasonb said:yeah but that's a wide track axle. It's a decent amount wider than the 8.8, around 5" I think. I guess some spacers would solve that, but they'd be pretty big spacers.
21robbie21
Elite SPort
- January 11, 2004
- duluth, ga
- explorer sport 2001
if im getting new shafts could i get them lengthened or would that be impossible or too much trouble?
IZwack
Moderator Emeritus
- February 5, 2003
- Germantown, MD
The axle tubing would need to be lengthened too - the proper term I think is re-tubed. You can do this yourself, you just have to buy new axle tubes. Altho you will probably need a machine shop to press the tubes into the diff housing (they need to be aligned too). I once found a webiste that had axle tubes, but now I dont remember the site or company. But search around on google if your interested in retubing, I'm sure you'll find a few sources. The website below mentions retubing the 8.821robbie21 said:if im getting new shafts could i get them lengthened or would that be impossible or too much trouble?
http://www.code4x4.com/projects/axle_88/axle_88.html
The other option is to find an 8.8 from an F150 or something - I think their rear ends were a little wider.
21robbie21
Elite SPort
- January 11, 2004
- duluth, ga
whats the WMS to WMS of the explorer 8.8, because my d44 is 63 or 62.5 and that last link you haze izwack, the guy said he made the 8.8 3" overall wider for a 65" WMS to WMS, meaning the 8.8 is alreay 62? i think if its only an inch or so ill just use spacers
IZwack
Moderator Emeritus
- February 5, 2003
- Germantown, MD
not sure what the WMS-WMS measurement of the stock 8.8 but since your adapting a new bolt pattern, just go with wheel adapters - they will change ur bolt pattern from 5 on 4.5 to the 6 on 5.5 that the d44 is on AND space your rear wheels out.
bmxking5
- May 2, 2004
- Monroe, GA
- '93 Sport & '96 XLT
^^Yep
I believe the stock rear is 59-60". The 5 lug Ford is 65-66 and everyone always says it's six wider than stock. Looks good, you bringing some of the parts on Tuesday?
JS91X
- October 16, 2005
- cumming, GA
- 1991 XLT
buy the time you get spacers that change it to 6 lug they'll be as much or not much less than a new set of superior shafts. id go with the shafts....only like $ 250 if i remember 034x4s price right
IZwack
Moderator Emeritus
- February 5, 2003
- Germantown, MD
the wheel adapter thingymajigs are around $100 or so. I think Ive seen them for less than that too - maybe around $85 .. and thats two birds with one stone (lug pattern and width)JS91X said:buy the time you get spacers that change it to 6 lug they'll be as much or not much less than a new set of superior shafts. id go with the shafts....only like $ 250 if i remember 034x4s price right
- January 14, 2001
- Fresno CA
- 86 ranger no more
- Callsign
- KK6TDL
IZwack said:the wheel adapter thingymajigs are around $100 or so. I think Ive seen them for less than that too - maybe around $85 .. and thats two birds with one stone (lug pattern and width)
Not the 5 on 4.5 to 6 on 5.5 spacers. The problems is a few of the holes end up being very close together. It ends up having to be a 2 piece design. Only a few shops even make them and alot of places that sell wheel spacers wont even sell the 2 piexe spacers. Eather convert the front to 5 on 5.5 or get new rear axle shafts.
IZwack
Moderator Emeritus
- February 5, 2003
- Germantown, MD
This is what I found what I was going this route (2 piece design - Wheel Adapter 5 Lug 4.5" To 6 Lug 5.5 Thickness 2" ):RockRanger said:Not the 5 on 4.5 to 6 on 5.5 spacers. The problems is a few of the holes end up being very close together. It ends up having to be a 2 piece design. Only a few shops even make them and alot of places that sell wheel spacers wont even sell the 2 piexe spacers. Eather convert the front to 5 on 5.5 or get new rear axle shafts.
http://www.ezaccessory.com/Wheel_Adapter_5_Lug_4_5_To_6_Lug_5_5_p/5450-6550.htm
034x4
- January 16, 2005
- B'ham
- 2003 Ranger Edge
Somethings not right about that. One of the holes WILL over lap. My rotors were re-drilled to fit the 6-lug flange on the axle shaft and there is one factory hole on both rotors that is over-lapping with one of the new 6-lug holes.
- January 14, 2001
- Fresno CA
- 86 ranger no more
- Callsign
- KK6TDL
Because it is 2 piece one lug is ontop of another. Look at it this way. You have 1 set of lug nuts holding the spacer to teh axle then one set of bolts holding the spacer to the spacer most likely threaded into aluminum and then you have a set of lug nuts holding the rims to the spacers. Add to that you are probably running a 35-37" tire and rim combo that weighs probably over 100lbs on your 5000lb explorer that will see some abuse on teh rocks. Not quite the same beast as the mustang rinning 18" rims on the street that they talk about in the description.
If you are going to go through the whole brake system and bearings up front anyway it really isnt that much more expensive to swap it to 5 on 5.5 (just need spindles)
IZwack
Moderator Emeritus
- February 5, 2003
- Germantown, MD
I are not running this setup (going to 5 on 5.5 d44 and a ford 9") but I just wanted to throw that out as an option. I think there are others that have ran a lug pattern conversion or had the axle shaft redrilled and then spaced.RockRanger said:Add to that you are probably running a 35-37" tire and rim combo that weighs probably over 100lbs on your 5000lb explorer that will see some abuse on teh rocks. Not quite the same beast as the mustang rinning 18" rims on the street that they talk about in the description.
EDIT: going to run 8-lugs (convert the front d44, run a 14-bolt in rear)
21robbie21
Elite SPort
- January 11, 2004
- duluth, ga
well i guess ill get new spindles up front and spacers in the rear and make it 5 on 5.5, what sites have you guys ordered parts for your rebuilt axles from? do you guys think i should buy this its a basicly stock waggy steering system, ive been reading on skunk/lizartrac's SAS and he used the same axle as me with the stock leaves SOA and used the stock steering with a custom bent drag link, if that suff ended up going for like 200+50 shipping, is that way to much, especially not knowing if i can make it work? if im looking for a stock system should i just keep junkin around? i figured i could try out the stock stuff and then if i have to upgrade certain components to high steer. Jason B let me borrow the sandblaster, so im working on cleaning everything up well, it sounds like a nice deal getting to use it, but man is it work, ill post pics wen im done sanding, grinding, priming and painting
- April 16, 2001
- Suwanee, GA
- '99 Sport 4x4
I wouldn't buy that and pay $50 shipping. I'd get a local shop to make one for you. I can recommend you to a few in the area, one really close by.
The 5 on 5.5 stuff... I have a friend selling some of that.. let me check with him tomorrow to see if he still wants to get rid of it.
Sounds like you are having trouble with the sandblaster? keep watering up on you? Compressor not keeping up? The tip is getting pretty wore out but last time I used it everything was smooth sailing.
Similar threads
Completed Project
jamest's "RE-SAS"
- Replies
- 266
- Views
- 64,603
- Replies
- 10
- Views
- 1,847
- Replies
- 312
- Views
- 89,964
- Replies
- 15
- Views
- 3,115
