- January 22, 2007
- selkirk, manitoba
- 98 supercharged 347 sport
i just remember what a pita that whole cam sync thing was...
Unless you ment bank instead of cylinder, that would be cylinder 5.I moved injector 1 to cyl 2
Definitely the GPR here. Pulled out the multimeter and it's deader than a door nail. If the glow plugs don't get power, they can't heat up. Most of the year it isn't warm enough to need glow plugs here, so the failure can go unnoticed for a while. Plugging it in provides enough heat in the block that it starts easily even without the glow plugs on a ~30° morning. Probably wouldn't if it were colder here though.I live and breathe 7.3s I have 3 of them
Cold start issues normally injector seals and o rings on a 7.3.
Re ring injectors, clean and inspect injector
Cups, replace new zd11’s, new international valve Cover harness. If it’s an obs upgrade to superduty valve covers and wiring.
Upgrade that gp relay to a Stancore
Cylinder 5!! Silly me
not sure where my head was at
I’m really nervous,
I get this way when I just put an engine together, the old one blew up, and I’m about to turn the key
let’s see I put together 6ea 302 in the last year and 2 of them failed on the test drives, 2 are still running great and one is about to be started for the first time…. Nerves wrecked but I’m used to this
Cross your fingers it runs properly and we can start the Holley tune Eddie really needs his truck back
I had thought of that, it seemed to be weird in my mind as the boot would be about halfway up the shifter.@dvdswan
There's been a bunch of people do the Explorer full console swap with a manual transmission in a Ranger. The shifter comes up where the info display or storage cubby would be. They use an aftermarket boot to fill in the opening. Wouldn't surprise me if manual swaps have been done on Explorers with similar results.
Most of those were with a V6 and Ranger transmission, but I think the 5.0L W/M5OD puts the shifter in about the same position.
It's up there, but IMO it does not look terrible. Here's a link to a Ranger forum that has a few pics of it done. I particularly like the results with the hurst shifter one.I had thought of that, it seemed to be weird in my mind as the boot would be about halfway up the shifter.
Those actually look pretty good. The Hurst one is nicely done for sure.It's up there, but IMO it does not look terrible. Here's a link to a Ranger forum that has a few pics of it done. I particularly like the results with the hurst shifter one.
EDIT: Helps if I actually post the link. Exp Center Console /w Manual Trans - Ranger-Forums - The Ultimate Ford Ranger Resource
