Now after some testing of the wiring and the new lights I decided to make a few changes.
I wanted the flat light bar (above the projector) to illuminate yellow and flash with the turn signal
So I installed some 194 yellow marker bulbs:
and I made the following wiring changes:
This is the stock (truck side) light socket for the top turn signal
It attaches to the new light here:
yellow bulbs go here:
Now to cut the wires:
brown CUT WIRE from truck now becomes power for halo's (parking lamp 12V+ feed)
1. Green from new light wired to brown, truck side (now + for halo ballast, from above)
2. Black from new light tapped into black ground (- for halo ballast, from above)
3. brown power feed to new yellow bulbs tapped into white/green (signal flasher from truck)
---ONLY DO #3 if you want your flat bar to be a turn signal not parking lamp as intended from manufacturer---
now to fit the light
Wires route in prep for light (for best fit), ballsts go through the holes the wires are coming from
light wired in prep for fitting:
Note bluew socket on top right, red and black wires get pushed into the light and tan colored plastic fitting is twisted into the housing
turn signal bulb also gets pressed and turned into housing
not pictured, not lots of room to work here
NOW the grill goes on, it is not easy to get the lights through the grill and grill around lights, very carefully here:
Then the lights go in, press in 3 places like factory side marker and two top screws hold them in place
grill installed
ballast is hung, I dont trust 2 sided tape behind the grill for long:
I removed the battery and also zip tied the other ballast in place as well as loose wiring
installed!
Oops fitment issue with grill:
the humps on top of the new lights dont clear:
cut some plastic away with air grinder, careful here:
Perfect fitment, I am impressed with the engineering in these new lights ($$$$$$$):
Bulbs are Sylvania Extra Vision, high and low beams (h3 and H1)
LIGHTS HAVE NOT BEEN AIMED yet
Lows:
Highs:
halo's:
Video of the functions, note the yellow bulbs were not installed yet here:
http://fortuneelevatorconsultants.com/XLT/lights/xltlights.wmv
