- January 28, 2000
- Huntington Beach, CA
- 1991 Eddie
hey bud which question do you still have the 33x10.5 boggers? how much tread life is left, im lookin to downgrade from my 37" boggers to 33" boggers let me kno
extend the radius arms.
Yeah I guess you could do that.
Yeah it will fix the problem.this is on a budget, and i being used to mud bog.. when my poor self gets some more money ill be building tubular radius arms.. but you think for now just move them r.a. mounts forward will solve my problem?
Oh and if its going to sit that tall, your caster looks off -- looks like you have negative caster. Probably doesnt matter if you're just going to bog it, but if you drive it on the street, it can get hairy to handle with a negative caster.
It might fix the caster just by a hair but not much. When the springs settle, it might also help with the caster too but again not much.yes i know its negative lol... thats what im saying, by moving my ra mounts more forward will this fix all of that problem, ly caster and putting my tires below and insid ethe wheel well????
Yes but you mud bug people require tall vehicles -- where rock crawling doesn't require as much heighthmmm so it could also help if i raised my spring buckets up a little higher?
Try raising the coil mounts first, then if that's not enough, move the radius arms forward (or extend the arms).so you think its a better idea to raise my coil buckets to get my tires to move more forward?
