Turbo Time!!
After lots of debating Ive decided turbo is the way to go. The initial cost of nitrous is just about the same. Long term it is not cost effective or convenient, nor am I keen on having bottles take up precious cargo space. I have a lot of respect for the m90 and m112 guys, but don't get me started on them, it's just the wrong direction for me. So turbo it is.
Initial hardware budget was set at $800 or realistically $1200 + infinite man hours + more money. $1400 is what I originally paid for the explorer, so I need to keep it under that. Currently I sit over $1300 lol. Parts list will be updated throughout the project.
Acquired parts so far:
Holset H1C used, from '94 Cummins with rebuild kit and lightly used aftermarket intercooler - $140 craigslist
'03/'04 Cobra maf (90mm) and injectors (39pph) all genuine Ford parts, used, claimed less than 20k miles. Look new. - $232 eBay
TRE 255LPH fuel pump - $78 TRE eBay store
http://treperformance.com/i-63668-ford-explorer-255-lph-fuel-pump-1997-2003.html
Bosch BOV used, from a Porsche - $30 eBay
Turbowerx Base Model oil scavenge pump - $267 Turbowerx eBay store
http://www.ebay.com/itm/24V-VERSION...Parts_Accessories&hash=item19ed1dbb58&vxp=mtr
3" flexible charge hose - $117 Amazon
http://www.amazon.com/dp/B0050IK4W6/ref=biss_dp_t_asn
2.75" - 4" 90* Silicone - $16.95 eBay item# 120721216895
2nd gen Explorer power steering cooler - junkyard
lots of Explorer fasteners and radiator rubber mounts - junkyard
Autolite AR103 14mm Spark Plugs (8) - $29.92 eBay item# 400723808580
4" 48" exhaust tubing - $21.97 SummitRacing SUM-640040-1
4" 90* exhaust tube - $21.97 SummitRacing WLK-41256
O2 sensor bung - $1.90 SummitRacing VPE-11105
Pack of 10, 3" t-bolt clamps - $15.99 eBay item# 371037478216
4" silicone coupler - $8.44 eBay item# 261479866521
2.75" to 3" straight silicone (2) - $6.88 each eBay item# 191141733182
3" aluminum pipe joiner (4) - $11.98 each eBay item# 261036332975
4" to 3" Silicone coupler - $7.99 eBay item# 261506451986
3" Stainless v-band rings and clamp - $29.95 Amazon
Gasket set for Turbo exhaust inlet - $12.93 Amazon
Painless Wiring 70103 Circuit fuse-block kit - $62.79 Amazon
Soon to order:
VDO Turbo gauge - $52.38 SummitRacing VDO-150-1212
VDO Oil pressure gauge - $66.33 SummitRacing VDO-A2C53413151
4" t-bolt clamps (pack of 4) - $13.78 eBay item# 291058649828
The turbo is in great shape, the guy claimed less than 150k miles on it. Axial and radial slop were well within spec but I had the rebuild kit and was curious of the guts so I rebuilt it anyway. I seconded guessed my balance marks so the shaft assembly is currently at a diesel shop being balanced, should have it back Mon evening or Tues morn. - $100
So from TB I plan to go:
2.75" to 4" 90deg silicone - straight section of 4" tube - 4" silicone - maf - 4" 90deg pre-bent where airbox is - 4" to 3" silicone - 3" aluminum silicone coupler - flexible 3" hose - 3" to 2.75" -intercooler - 2.75" to 3" - flexible 3" hose - turbo charge side. BOV will be in there somewhere.
Turbo oiling:
Pressure sending unit T fitting - turbo oil inlet - turbo oil outlet - scavenge pump - valve - filter - valve - oil filler neck. Ill have to make the fittings to get oil in and out of the turbo. Oiling is my biggest challenge right now. Not sure where the oil cooler should go if at all. I think oil from the turbo needs to somewhat gravity feed to the pump.
Tuning:
I will eventually tune it myself using 2000StreetRod's EXTREMELY helpful and informative tuning threads. Hopefully the thing runs well enough on my strategy tuning. Initial boost will be as low as I can get it (8psi?), then boost up with head studs until I feel the bottom end is shot. The turbo is a beast and is good for 30+ psi on a 5.9 Cummins.
For vacuum I don't know yet. There are a ton of oem automobile check valves on eBay. Hoping to get some help in this area.
For fuel I could not find much on FPR's. I'm a bit confused. Won't the FPR maintain a specific pressure up to a point? I noticed there is a vacuum line right by the FPR, I need clarification please. Hoping to get some help in this area.
Suggestions and advice are more than welcome. Idk much about this stuff, just what I've read. Please don't tell me the turbo wont work with this engine and the 422 cam. I know the exhaust side is monster and will take time to spool, that's fine with me, I want the turbo dormant unless I nail it.
I currently am taking my last class at school, one night a week and I wont be working until mid-August. With that said I have nothing to do but work on the explorer and tan. So things should move right along as parts arrive. This will be a learning experience for us all. Hope you guys are excited as I am
