Auto to manual transmission conversion | Page 2 | Ford Explorer Forums
Thank you for the info! All this knowledge helps many folks.
You can install a sohc clutch on a old ohv engine
All you have to do is remove the 3 alignment dowls from the flywheel and set the sohc pressure plate clutch on top with alignment tool. Now you can mark the 6 holes needed for the clutch to flywheel bolts. Drill them and tap them… now you have a old 6 bolt
Ohv flywheel and a larger self adjusting sohc
Clutch. I run a luk clutch made for a 04
Ranger sohc
I also run luk hydraulics always
I won’t install cheaper non luk clutches or slave cylinders
