Barack Obama linked 2nd gen. SAS | Page 33 | Ford Explorer Forums
Thanks everyone! :D
LOL I know, Performance Accessories is looking down at me right now :(
well thats what they get for refusing to sell late model explorer products!
Congrats. Thats a sick picture.
wait a minute, you photoshopped Barack Obama into the name. So what do i get for catching the edit?
A cookie?
acually froader did it, it was correct earlier.
Ahaha that FROADER :D Always correcting the wrong.
Looks fantastic griff!
I'm a newb when it comes to desert suspensions so do tell: why are there always two shocks per side? Is it because the shocks are placed on the arms so there's too much force from the mechanical advantage ? Ive watched a few desert videos and I always wonder why they cant run a single shock.
When the gas heats up in the shock it makes the shock less effective.. so they use 2. Same thing with the resivoirs, it helps the shock cool faster because trophy/dessert trucks us them to the fullest extent.
That was my thought, but why cant they just run say a reservoir thats two or three times the normal reservoir volume.
Well.. most dual setups are valved so they share the load, but the newer shocks of "today" can take a lot of punishment. So unless its a true baha race vehicle one should be just fine. As for a larger reservoir, I dont know if they make them? I dont know.
And to correct what I said earlier, the OIL heats up in the shock making it foam.. and the high pressure gas in the shock stalls the process somewhat.
holy crap batman, das ist expensive shocks.
So just who IS Harold Nacion?!?! He is awfully brave letting someone else fab on his sploder......
Some loser :D
Kaiser, tell me more about your J-series :D What gear ratio?
I was going to use a set of axles from that M-series once but some1 beat me to the Ebay auction :(
The front is a closed knuckle, small tube Dana 60 (30 spline shaft is the biggest that will fit, but there are some very $pendy 300M shafts out there) and the rear is a Dana 70. They have 5.87:1 gears. They also have an odd-ball 6 lug bolt pattern that is shared only by some UPS trucks (as far as I am aware). They do have the biggest drum brakes I have ever seen on a "light duty" (under 2.5 ton) truck. I cannot get my finger in between the stock 16" wheel and the drum. Overall, there are much better choices if you are going to swap them into something else (esp if you want disk brakes). At some point in the future I may look for a newer Dana 60 and a 14 bolt to get disk brakes and a little more strength. We will see.
What else do you want to know?
Iz. I was wondering how you got you axle ready for the links to be welded to the axle but now that i have wasted thirty mins looking i finaly noticed yours was ready to go when you go it.
What is the best way to get rid of the cwedges or what ever they are called that the stock radius arms bolt around.
Nothing else, just missed hearing the interesting characteristics those fascinating M series :D
The D44 was not ready for links when I got it. Being a Wagoneer axle, the D44 I used previously sat on leaf springs. I sliced off the stock spring perches from the tube (among other things like the inner-knuckles or "C"s):
Afterwards, it was just a matter of welding the tabs for the links. The tabs for the bottom links were purchased and just needed some minor modifications (they were meant for 0 degrees mounting, the bottom links are angled in at the chassis end so just a little bit of grinding was neeed). The upper link tabs/mount was cut from 1/4" steel and welded to the housing with hi-nickel lo-hydrogen electrode.
Again the D44 I used was previously leaf-sprung so I didnt have to deal with C-wedges, but from what I can remember, most of those C-wedged axles do not have an axle tube under the full length of the casted-wedge part. So you cant just remove the wedges w/o planning ahead of what to do after its been removed:
(more info here: http://77cj.littlekeylime.com/Dana44.htm)
If you want to go to independant links from C-wedges, I'd just get another D44 housing with leaf springs or links. SavageWolf did something about the C-wedges, I forget exactly what but its in his SAS thread (I remember a pic of something in the oven to heat it up)
EDIT -- this thread has been viewed over 23,000 times <-- geezus!
That’s because you’re my idol and I look at it every day....lol
LOL Naw it’s because you have a well built Explorer that is worth the views.
Ill give SavageWolf a look over. Thanks
LOL wow Burns.
Okay time for a steering discussion:
Recently, the steering has been very weak when turning left but does okay turning right.
Is this a pump problem or a steering box problem?
I havent checked this yet but I was thinking maybe the belt is slipping on the steering pump?
If it matters, I'm using the stock 2nd gen steering pump hosed to a Toyota IFS steering box (that I bought for very cheap;)). Also, I replaced the pump maybe 7 months ago.
If it was the belt wouldnt it be weak both ways and not just to the left?
