- November 29, 2000
- Location
- USA
- San Diego, PRofK
- 1994 XLT
Got it, thanks gman.
I dropped the transmission pan today to see what I could see. I messed around with the wiring, but there was no power on the switched wire inside the transmission. I jumped the wiring and it all worked. I could see the pressure switch move. Hmmmm, what the heck. I had pulled the plug with the wiring to the transmission when I jumped the lines, and as I was looking at everything I noticed something. The wire for the manual switch was wired into the wrong slot! According to Bowtie's instructions I had the external wiring right, but they had the internal wiring wrong. It was easier to move the external wire, so bingo, bango, bongo. I now have a working manual torque converter lock up. I never realized it wasn't working all these years because I didn't know any better. The OD lock up was wired wrong by the installer so it never worked until I did the rewire of the entire Explorer after it melted. It was then that I noticed a difference when the trans went into OD and automatically locked the converter, and unlocked when braking. I think I just solved my issue with the trans getting so hot on long grades. I ordered a red LED light I can mount somewhere visible to be on when the converter is locked that will hopefully remind me to unlock it before shifting.
It started raining so I didn't go for a test drive, but should get it out sometime this week.
