Any more progress here Dave?
Sorta kinda...everything I've started is half done mostly because I need to finish the cage. I had the reroute my exhaust since i'll be running the shocks in between the frame rails again. The shocks can't be mounted until I get the bed section on the cage done because the shocks will be mounted to it.
I've got the B-hoop and A-pillar bars bent, the bottom legs will be cut and spliced because I didn't wanna risk screwing up those long lengths of tubing.
Main tubes are 1.75 x .120 wall DOM, support and cross bars will be same size but HREW. The B-hoop legs land on the top corner of the frame and the A-pillars will land on the side of the frame. I removed the side vents and had to remove/relocate things in the dash so the A-pillar bars could pass through the dash.
Other odds and ends...I wont be running much of an interior, just carpet up front with seats and dash. Not sure if I could fit the headliner back in since I had to clearance the support structure for the roof to fit the A-pillars. I sprayed some undercoating on any of the exposed metal of the interior. Not sure it's gonna do much for sound or insulation but it looks uniform at least.
Scored some replacement parts over the last few months, got fenders from RangerX...thanks Bill
and got a hood for $25 off DR, side windows, rear slider, 3rd brake light for $40 also from DR. The side windows are pop outs and mine were originally fixed windows but no biggie, just had to pop rivet in the new mounts and they bolted in.
Rear window won't quite fit since the top of the cab is racked towards the drivers side but it will have to do.
So that's where i'm at, i'll snap some pics and post em up later.
