Mesozoic
- October 3, 2015
- Tucson, AZ
- '00 Mercury Mountaineer
BTW, I did encounter a small snag. This is typical with aftermarket high performance stuff. The flexplate in use is not the OEM unit anymore, but this PRW unit that's SFI rated and quite a bit thicker than stock. The torque converter is also not OEM anymore, but a custom built unit (as all of them are) from Precision of New Hampton. The new converter does not have studs for connection to the flexplate, but comes with some 3/8" fine thread cap screws (and no washers).
The flexplate's holes do not align precisely with the converter's bolt hole pattern. This required slotting the holes in the flexplate so that they would accomodate the fine threaded bolts provided in the converter kit. I used a pneumatic die grinder with a 3/8" carbide bit with flat top, so if contact was made with the torque converter it was relatively inconsequential. Once that was done and cleaned up (3 of the holes required minor slotting), everything went together nicely. Something to keep in mind that it may be a distinct possibility when upgrading parts.
