Okay update (still no pics yet need new camera batteries)
We were having a clunk in the transmission after changing the fluid and filter
This has been fixed, I failed to plug in the MAS the other night after doing a full tune up.
Wheeew! I was online researching the 4r55e clunk issues assuming the worst! Thank goodness it was something simple...
The truck is now 99%, I am still getting an EGR code, Insufficient EGR flow
I have yet to remove the EGR valve and check the diaphram for problems. I assume it needs a new EGR valve.
The truck got a new 02 sensor (had one laying around) and that took care of the 02 sensor code.
The multifunction switch went south yesterday, after attempting to use the hazzard lights the turn signals and hazards stopped working.
I took the multifunction switch apart and cleaned all the brass contacts. I also repaired the hazzard button contacts, one of them had come loose inside its housing. The signals and hazzards now work again, FREE repair!!
truck will be getting next:
transmission cooler install (this truck has no aux cooler from the factory, I have a V8 style cooler we will be plumbing in)
Rancho 5000 rear shocks (had them laying around)
new tensioner pulley (had this laying around)
I am going to crank the torsion bars to fix the factory sag, then it will get an alingment.
Brown wire mod
Going for emissions next week! Beautiful truck for thousand bucks!
