MuscleJunkie
- April 14, 2007
- '00 Ford Explorer LTD AWD
Saw this advertised and was wondering if it will fit on our Explorers?? Any reason not to use it??
Your Ford 8.8" Differential does alot of heavy lifting, why not dress it up and help cool it down at the same time with this Saleen Aluminum Rear End Girdle. This lightweight differential cover is made from 356-T6 cast aluminum and features a reinforced crossbar with load bolts to provide additional support for differential bearing caps to reduce bearing cap fatigue and failure. Manufactured to exacting specifications, this differential cover goes through a unique 3-step manufacturing process to insure accuracy and the high quality you've come to expect from Saleen.
- Incorporates a Fill Port and Drain Port for Easy Servicing
- Incorporates 2 Load Bolts with Swivel "Feet" For Supporting Bearing Caps
- Increases Fluid Capacity by Approx. 1/2 Pint, Reducing Operating Temps By as Much as 15°F
