New supercharger
I am relatively new to the website. I am allways looking for possilbe upgrades to my X, so in digging around I found what may be the golden key. I am only in the investigation stage. I don't have alot of info yet, but it looks like they have developed a stealth supercharger for the 4.0 L Mustang, and are looking at a conversion kit to mount into an Explorer. What makes this supercharger so awsome is that unlike most others, it's boost starts just off idle and has a very linear curve all the way through the rev band. ( So you don't just get a hit at 4000 rpm to redline.) Also, you can adjust the psi boost externally. So if you have it set to 5 psi, ( Approx. 55 hp. gain and 70 ft torque) you don't even need an intercooler set up. It comes with it's own oil cooler that is mounted off the radiator, so you don't even have to tap into the oil system. The supercharger is about the size of an alternator and is serpentine belt driven. It's almost a plug and play supercharger. Now, I don't know that you will get 55 hp from 5 psi on a 4.0 L X. Nobody has tried this combination out yet. I am in talks with the developer about installing one in my truck and doing a photo layout and install description in return with results. :biggthump
Looks like we will be guinee pigs and have to break some uncharted territory. If anyone else has been down this road please send me some feedback. What did you like and not like? How much did you spend ? And anything you learned along the way could be very helpful. Thanks guys and I will keep you posted as this developes.![Biggthumpup :thumbsup: :thumbsup:](/forums/../forums.old/images/smilies/biggthumpup.gif)
