I'm trying to test out the waters here. I'd really like to start accumulating the parts for me swap, but I don't plan to get to work on it until the summer. A question for all you SAS vets: What else would be needed besided the parts listed:
dana 30 from an xj (one piece shafts no vac discos) 4.10 gear ratio. all the xj brakcets have been cut off and sanded smooth ready for the EB setup.
axle was cleaned and primed and painted black
brand new still in box rotors
rebuilt capipers painted red.
brand new in box brake pads
brake lines
crome diff cover
EB axle wedges and 2.5 id 2.75 od tubing to build up axle housing for the EB wedges.
brand new still in box daystar bushings for EB front suspension. (red)
brand new still in box wild horses 5" rockcrawlers (red)
tie rod and drag link from yj.
EB coil buckets and spring keepers. cleaned and primed and painted black
EB bottom coil buckets cleaned and primed and painted black
EB radius arms (cut and ready to have caster arms made out them)
EB track bar and frame mount
Jeep track bar and frame mount
ranger power steering box with both lines and pitman arm
EB shock mounts
BTW, this list comes from a lot that someone is selling, so I just want to know what else I will have to buy. Thanks for the early help!
brake lines
crome diff cover
EB shock mounts
