HID Install +Pics - Step by Step
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve
Callsign
VE3
Talking to salesman that I dealt with , he is going to speak with service manager to see if sport housing can have hids from limited wired up and used in that housing. Keep ya posted even though I dont have good feeling or that anything will come.of this, but we will see.
Even if you can, and you likely could, it still has a 'housing' not meant to be used with HID lamps as mentioned in post 95. The only proper way would be to change the housing as well to one designed specifically for HID bulbs.
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
deadmanx
370z sold Now 2014 Xsport
It comes as a whole assembly, apparently you can't get parts seperate. It can be done by putting the limited housings into the sport. So ya peter is correct.
Wildcat_1
2013 Explorer
DM, any talk of price ?
Thanks
deadmanx
I think they are listed on the ford oem site where you can find parts. Expensive is my guess. You would still be missing the nice blacked out housings which sucks :/
Wildcat_1
2013 Explorer
Can of Kryon ? :)
deadmanx
Ya it can be done just Pita. I bet those housings are 700$+ I asked so we will see
peterk9
Staff member
Moderator
Callsign
VE3
http://www.oemfordpart.com/parts-catalog/ford/explorer/2013/limited/3-5l-v6-gas/electrical/headlamps
Found something little interesting. I would love to compare the differences between projector hid vs halogens.. they look very similar from what I can see
One thing I have found in checking fordparts.com is that Ford often has the same part number for parts that are not exactly the same. One member and his dealer found that out when they ordered and installed the lower front air dam. It turns out the one they installed had the cutout in it and the original did not. Dealer had to reorder and re-install the correct one. Both had the same part number.
breshi
2013 Ex Limited FWD V6
deadmanx
http://m.ebay.com/itm/261163763185?nav=SEARCH
http://m.ebay.com/itm/400642726489?nav=VI
So there are the 2 different housings, the goal would be to change that projector / lens that is.in the limited and swap it with the sport. It looks like it could possibly just be clipped in and we would be able to swap them. You can clearly see the ballast and mounting points are on both housings. Plug n play? see if anyone else can spot any other differences , the lens is def different though
Edit: looking at it closer they look almost identical.. so I dont really know anymore ! Lets see ehat everyone else thinks
deadmanx
Does anyone have access to a housing to see if that lens comes straight out from the back or is it the whole assembly. It looks like it possibly has clips not sure though, but if that were the case wow that would be a simple change and then you have factory hids essentially
mctee
Vancouver
2016 Ford Explorer Sport
No. The projectors can only be removed from the front of the assembly by separating the clear front cover from the backing.
Check You Tube for video on how to...
deadmanx
So did someone do.this to.the sport then and has a vid? Link??
Sgt1411
VanBC/GoodyearAZ
2017 Explorer SPORT
I'm local here in St. Louis, and will be picking up HID kit from http://www.diodedynamics.com/store/2011-2014-ford-explorer-low-beam-hid-conversion-kit.html does anyone have any pros/cons to using them? I have a 2014 Explorer Limited and am going for the "stock" hid look too
Those HYLUX ballasts seem to have good reviews.....make sure you grab the CANBUS version ballasts.
Pretty good pricing too, you going for 4300K to replicate OEM look?
Why does it say Low Beam only though?
peterk9
Staff member
Moderator
Callsign
VE3
That caught my attention as well since we just have the one bulb.
kennybahr
Kirkwood, MO
2014 Ford Explorer Limite
I'm not sure why it says low beem, but I went out to the HQ today, really nice place, and extra super cool employees, I would have to say this is a "top notch" company!!!!!! I'll be installing these tonight, I'm a professional photographer, so I will be posting pictures...hopefully later on this evening!!!!
Sgt1411
VanBC/GoodyearAZ
2017 Explorer SPORT
Great I will be awaiting the photo's
deadmanx
Ya I would like to see some.good pics of these.. if they look like xenon hids should.then I may go this route.
M HID Install - Fogs +Pics Modified 2011- 2019 Explorers - Tuning & Mods 13
N HID Conversion Kit... eh, rethinking the install Modified 2011- 2019 Explorers - Tuning & Mods 31
S Battery saver mode after HID install Modified 2011- 2019 Explorers - Tuning & Mods 8
A HID Fog Install Questions Modified 2011- 2019 Explorers - Tuning & Mods 20
M Any Canadian's install HID's? Modified 2011- 2019 Explorers - Tuning & Mods 2
C HID's or LED's - these halogens have to go Modified 2011- 2019 Explorers - Tuning & Mods 3
C User reviews on HID kits (consolidated) Modified 2011- 2019 Explorers - Tuning & Mods 20
N Diode Dynamics HID Users... come on in! Modified 2011- 2019 Explorers - Tuning & Mods 22
T Removing OEM Hid Headlight Bulbs Modified 2011- 2019 Explorers - Tuning & Mods 7
T HID Beam Pattern Thread Modified 2011- 2019 Explorers - Tuning & Mods 1
N 2015/2016 Ford HID/LED vs Aftermarket... which is better? Modified 2011- 2019 Explorers - Tuning & Mods 15
R 35W or 55W HID bulb Modified 2011- 2019 Explorers - Tuning & Mods 34
R 2012 headlights hid to halogen Modified 2011- 2019 Explorers - Tuning & Mods 5
S DDM HID Slim Kit Issues Modified 2011- 2019 Explorers - Tuning & Mods 10
J HID/LED Headlamps and/or Fog Lamps - GO LIONS!! Modified 2011- 2019 Explorers - Tuning & Mods 3
D Informative Pros/Cons Halogen, HID, Retrofit lighting setups Modified 2011- 2019 Explorers - Tuning & Mods 0
C My Drivebright.com experience (HID and LED Swap) Modified 2011- 2019 Explorers - Tuning & Mods 22
2 One Side HID Not Working Modified 2011- 2019 Explorers - Tuning & Mods 17
C Having an issue with HID's Modified 2011- 2019 Explorers - Tuning & Mods 18
P Which Headlight HID Kit??? Modified 2011- 2019 Explorers - Tuning & Mods 34
S Ford explorer HID get exchanged to Halogen by dealer Modified 2011- 2019 Explorers - Tuning & Mods 9
1 35W vs 55W HID? Modified 2011- 2019 Explorers - Tuning & Mods 16
C Correct positive connection for HID relay Modified 2011- 2019 Explorers - Tuning & Mods 1
K 2014 Ford Exploer Limited HID from Diode Dynamics Modified 2011- 2019 Explorers - Tuning & Mods 26
J HID Conversion Problems-2014 Sport Modified 2011- 2019 Explorers - Tuning & Mods 99
C Canbus or regular harness for HID? Modified 2011- 2019 Explorers - Tuning & Mods 21
O HID's and Shark Fin on Leased Sport, input requested. Modified 2011- 2019 Explorers - Tuning & Mods 5
Sgt1411 Installing HID? Read this first. Modified 2011- 2019 Explorers - Tuning & Mods 168
J My experience w/ House of HID Modified 2011- 2019 Explorers - Tuning & Mods 25
X TRS HID or Cool Bulbs Modified 2011- 2019 Explorers - Tuning & Mods 12
R Question for the Folks that installed HID on the FOGS Modified 2011- 2019 Explorers - Tuning & Mods 6
M HID Upgrade in Canada Modified 2011- 2019 Explorers - Tuning & Mods 7
F Coolbulbs.com HID Kit Review - Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 24
I Coolbulbs All-In-One 6kk HID's (heads and fogs) in my 2013 Explorer Sport Review Modified 2011- 2019 Explorers - Tuning & Mods 8
J 2013 Ford Explorer Sport Tint and HID Mod Modified 2011- 2019 Explorers - Tuning & Mods 6
K Help with HID ballast mounting Modified 2011- 2019 Explorers - Tuning & Mods 15
R My last post ------- about HID! Modified 2011- 2019 Explorers - Tuning & Mods 3
G HID low beams/HID Fogs Modified 2011- 2019 Explorers - Tuning & Mods 22
M HID Light Installation - HELP!!!! Modified 2011- 2019 Explorers - Tuning & Mods 14
E Morimoto Elite HID Kit Installed Modified 2011- 2019 Explorers - Tuning & Mods 14
J Replacing OEM headlights with HID lights? Modified 2011- 2019 Explorers - Tuning & Mods 52
R 2013 LTD with HID Modified 2011- 2019 Explorers - Tuning & Mods 15
M Ford Explorer HID Conversion Kits - Installation Guide Modified 2011- 2019 Explorers - Tuning & Mods 15
J DDM Tuning HID Kits - Don't waste your time or money Modified 2011- 2019 Explorers - Tuning & Mods 6
S Ford HID bulb upgrade Modified 2011- 2019 Explorers - Tuning & Mods 9
R HID bulb problems Modified 2011- 2019 Explorers - Tuning & Mods 13
N My Sport with HID 8000K's Modified 2011- 2019 Explorers - Tuning & Mods 97
F New Guy with ?? on HID kits Modified 2011- 2019 Explorers - Tuning & Mods 17
N Ford Explorer HID Conversion Kits (problem?) Modified 2011- 2019 Explorers - Tuning & Mods 72
C Explorer 2011 - HID Headlight Issues Modified 2011- 2019 Explorers - Tuning & Mods 5
Similar threads
