still need answer to the above question. and what do you guys think about this?
http://store.summitracing.com/partdetail.asp?part=EDL-3722
Brand: Edelbrock
Product Line: Edelbrock Performer-Plus Camshafts
Part Type: Camshafts
Part Number: EDL-3722
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: Idle-5,500
Intake Duration at 050 inch Lift: 220
Exhaust Duration at 050 inch Lift: 220
Duration at 050 inch Lift: 220 int./220 exh.
Advertised Intake Duration: 282
Advertised Exhaust Duration: 282
Advertised Duration: 282 int./282 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.498 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.498 in.
Valve Lift with Factory Rocker Arm Ratio: 0.498 int./0.498 exh. lift
Lobe Separation (degrees): 110
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: No
Quantity: Sold individually.
Camshaft, Hydraulic Roller Tappet, Advertised Duration 282/282, Lift .498/.498, Ford, Small Block, Each
* Check to make sure this part fits your application
The heart of the total power package.
These Performer-Plus camshafts from Edelbrock are designed for optimum torque from the low-end to the mid-range. They are smooth idling cams for daily drivers, trucks, vans, RVs, and 4x4s. They offer improved throttle response and torque.
