Getting started....
Had to measure the installed height of the stock valve springs. For the record, 1.840
Stock retainers and push rods are out.
Stock timing chain is off
Stock lifters out
Stock Cam coming out
No this is not a pic from the latest hustler...
Cam went in, new thrust bearing on, new Elgin double roller timing chain on.
Stock oil pump
New Melling M68
New Comp Cams lifters in
New lifter guides and push rods in
New Ford Racing Valve springs, Comp Cams retainers and locks
Little trick, fill your cylinders with nylon rope to keep the valves from falling into the bore while changing valve springs.
Difference between stock and new
Another trick, use the valve spring compressor to break the seal between the inner retainer and the locks. Sorry for the blurry pic.
One side done, this is not a fast process.
Started to put the roller rockers on.
That is all for tonight, two of the valve retainers from Comp Cams were the wrong ones. I don't know how it happened, two in the pack of 16 were wrong. I have to make a trip to Jegs in the morning to swap them out. Tomorrow will be finishing the springs, finishing the rockers, oil pan and a few odds and ends, then to the track with the stang for the last track night that I'll be able to make this year.
Stock lifters out
Stock oil pump
New Melling M68
