I half arsed installed my J&S Vampire last night. (hooked it up, but didn't mount the gauge or brain).
I went for a drive on the highway with the vacuum port not connected and set the sensitivity.
After setting sensitivity, I turned around and hit the gas. Probably not the smartest thing I've ever done, but inquiring minds needed to know.
I eased in to it till I was at full wot. At about 70mph there was a shift and the rear tires broke loose for a moment. Then, they boost gauge hit about 14lbs and the Vampire gauge lit up like a Christmas tree. I let off the gas as soon as possible. I was afraid, very afraid.
I could hear ticking under the hood. Of course, I feared the worst. Keep in mind with a turbo (Depending on size of the hot side) you build lots more exhaust back pressure. My turbo, being rear mount, is a T3 (small) hot side (This is for quick spool, and I don't want high boost since I have a stock block. Did I hurt my fresh motor? Did I take out a header gasket? Why did the boost suddenly spike? Did I set my boost controller Wrong? I thought I had backed it off so I was only on waste gate spring pressure (6 lbs).
So, back home I went with all this whirling thru my mind. I popped the hood, and a hose had pushed off the dpfe valve. No surprise, exhaust back pressure pushed off the hose.
I checked my boost controller, and it is backed right off. I disconnected it, just to be sure. I'm going to have to go back to the exhaust shop and have my waste gate plumbed differently, as it should be plenty big enough to handle the extra exhaust to keep the turbo from creating too much boost for my application.
The exhaust back at the turbo (Where the waste gate is) is a 3" pipe. I just ordered a v-band clamp and flanges. This way, when the exhaust gets cut to do the waste gate, the v-band clamp can be added. No more cutting next time.
I need to get this waste gate thing sorted out before any more WOT testing so I can control boost.
