My New, New 347 | Page 19 | Ford Explorer - Ford Ranger Forums - Serious Explorations
My New, New 347
I'm abandoning my old thread (My new 347), as the motor has been an epic fail for many reasons.
Against any sane reason, I'm trying again.
Post #1 is a thread with all parts for my own records. I'll keep adding to this as I have the time and know what parts are being used.
New (Used) unmolested factory block from Vroomzoomboom. Thanks Tim!
Eagle Forged 4340 Steel Crankshafts 430234705400 w ESP Armor coat option
Bullet Pistons BF6010-030 - 2618 Forged Flat top w TFS valve reliefs made for power adder applications
Rods -I beam Forged (From Old Motor)
King Pro Series Bearings
Michigan 77 SH1321 Cam Bearings
MEL10688 HV Oil Pump - Block and pump machined to fit under the stock oil pan
FEL-1133SD MLS head Gaskets
PAC-1207X LS Springs (Yes Tim, there is something Cheby going in to my Ford motor)
Comp Ultra gold 1.6 rockers (old build)
HRC911968 Howards link bar lifters
Comp Cam 35-775-8 proposed, may change after head flow number change 35-775-8 - XFI™ Stroker Hydraulic Roller Camshafts, Computer controlled (E.F.I.) with O.E. hydraulic roller cams 1985-95
rollmaster timing set (Hopefully re-usable from old build)
TW170 heads (old build) that will be ported and the chambers softened for boost
push rods: 5/16" with a length of 6.7" (old build)
ARP Head Studs (old build)
Torque converter CircleD SKU:30-09-19 11" 2800 stall triple disk lockup FORD 11" HP Series 4R70 Torque Converter
Trick Flow Track Heat intake (old build)
Cometic C5652-060 intake manifold gasket
ARP Oil Pump Driveshaft Kit 1 54-7904 (old build)
ARP Flexplate Bolt Kit 100-2901 (old build)
PCV Valve EV127A
header gasket remflex 3003
28oz Damper DamperDudes.net (Americas Largest supplier of harmonic balancers)-re-balanced by machinist to 0
28oz flex Plate 1830201 - Small Block Ford 289-351W 1963-1982, 28 oz Ext-bal, 164 Teeth -re-balanced by machinist to 0
Injector Clinic 650H 62lb injectors
Return style fuel pump canister installed in fuel tank (1998 Explorer)
Another 6an braided line added as a fuel return line
Aeromotive Stealth Electric Fuel Pump 11542 340lph
Aeromotive 13130 fuel regulator
Trick Flow TFS-5158000R fuel rails
vroomzoomboom
Elite Canuck STOCK SUCKS!
selkirk, manitoba
98 supercharged 347 sport
Thanks Tim. The tough part is that the car needs to be fairly level, sitting on its tires before they go in. Without a hoist that supports the car on its tires, it would be less than fun. Nothing like welding sparks while your on your back, under the car. 🔥
jack stands under the torque box's, and i would have to believe your garage floor is level. that and ive done a few pairs of frame connectors. if you ever see joe again, ask him what happen when i was welding them into his car.....dumb ass lol
vroomzoomboom
selkirk, manitoba
sad day today. in a way i have been putting this off, and at the same time have had a bunch of other projects on the go, but today it happened.
don's truck is no longer powered buy a 347. soon the turbo and supporting mods will be removed and converted to a 4L
i really do hate this.
4pointslow
Explorer Torture Tester
Gloucester City, NJ
98 2Dr,98 & 04 4dr xlt
So sad to see it's demise. Maybe seeing it live on in another vehicle will bring back some joy!
Dono
347 V8 Limited turbo
Winnipeg, Manitoba
00 Limited V8
Yea, I'm hoping so also. I'm actually relived to to hear about the stripped valve cover bolt. In my defense, that bolt is right at the heater box and was an absolute bitch to get at. When the turbo oil return pump quit working, it wasn't pretty. Oil everywhere also. Im not sure if the turbo is hurt from it, no idea. Just way more than I could deal with at -40 degree's. Nice to see that Tim's the right guy to get this stuff. I'm quite happy to play with my mustang in the summer, and have a reliable daily driver now.
vroomzoomboom
selkirk, manitoba
but what will totally suck is if you and l line up. you in the stang, me in evil and i beat you in your mustang with your motor in evil!
also i just posted this in evils thread and i might as well do it here. motor appears to be in good shape going off end play.
vroomzoomboom
selkirk, manitoba
well its official. dons limited has now been castrated.
spent the last few weekends pulling everything out including de moding it, then getting it ready to put a motor that ford didnt even want in it. tonight it breathed for the first time with the 4L sohc.
i hate myself....
