- June 16, 2003
- Humboldt, KS
- 2000 Mounty
Well
FMS says an x cam should pull 13+ inches of vacuum.
I am idling at 16-17 ( I have a cab mounted guage)
Funny thing. This runs like a beast. I can do 60 from one end of the bridge to the other ( about 2 blocks give or take). Crusing around town does just fine, sounds like nothing else on the road.
On the highway I baby it, drive 70 mph, no revving over 3000 to pass, and have a best of 24 MPG, however it usually is about 21-22 hwy.
These reasons are why I feel a PCM and fuel injection is the way to go.
The surging ONLY occurs when slowing from highway speed.
The rev limiter sux balls, just getting into power when it hits,
dammmit
I need a flasher---If I spring, what should I do.
I am considering dumping the pro-m stuff and using a stock maf to tune from??? ( sensor only in a larger housing)
Thoughts????
I know there is something awry---this may help-- for some unknown reason, out of the blue, the torque converter quits locking up. It usually happens after a binge of surging. I scan for codes---none. try re arming pcm-- still no lockup. It is only when I disconnnect battery to reset the pcm that will get it locking again.
Out of about 7 long trips we have driven this setup, I have had to reset for this reason 3 times, half way there. Tach at 70 mph will read 2200 when locked--2750 or so when unlocked
anybody experience this??? I know it is the surging problem that causes it, I am assuming the trans is going into protect mode from the repeated lock- unlock while it is vroooming
dammmit
Thoughts????
