- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
oh my get a HP, I have never had any issues with an HP laptop, they are pretty tough
I made the mistake of buying from sears....then they wouldn't take it back....now it comes in handy for somethings....but I'd ,love to have something better......what did you have to buy to connect to your laptop?ok
I am using the easy obdII software off the scantool site
Awsome!!
I can drive around and watch all the trims-load values-ignition timing,Throttle position, temps, airflow, wow
I have been using a Davis Carchip for reading codes in the past. I'm going to have to buy one of these here toys
I have to say, the carchip is still cool, and yes I got mine from sears also,I got the Carchip on sale....of course it's been discontinued...but Sears kept a the receipt it was on from a different item exchange..and then said they never sold that model....man I was angry....I have to get a different one though...they are a pretty valuable tool.....first....I have to get that upper intake back on....it's been so windy and I have no cover until now(bought a Camping gazebo...been toying with taking the lower intake off and cleaning it but don't know if it would be worthwhile....or i'd have the patience......
mine doesn't have as many features as the Carchip EX....it works better for my Aunts Saturn SL2 1996 than it does my 2002 Exp. Sport.....I was looking for something to track down my lean codes and misfire codes.....so I would know weather or not I needed new O2 sensors...should take the Upper intake off.....Turns out(so far anyway) that not only were the o-rings needing replaced but the underside of the PCV hose elbow going into the upper intake looked like swiss cheese when I got it all apart....so I guess I had a double vacuum leak?!I have to say, the carchip is still cool, and yes I got mine from sears also,
it does catch all codes, and re-arm the PCM, plus captures data.
I just think this scantool is much cooler!!.
it can use software available from several sources.
plus
I just noticed
It measures speed in reverse!! wow
yup, as I was suspecting earlier, that pot is flaking out.
