My under hood "bug" | Page 4 | Ford Explorer Forums
My under hood "bug"
Wooo hooo!!
I just recieved a package all the way from Texas!!Is it a a bill? No, it is an adjustable IAC adapter plate thingy!!
SVO-Stang Girl--Thank you much!! :)
Now I shall go to the garage and istall this,
In the meantime, What do I do here?
Do I open my IAC screw on throttle body all the way, and adjust from this plate to bring it back down?
Also, about flipping the IAC valve over---A Guru on Stangnet mentioned this,
something about the return on IAC working better with cammed apps if it is backwards???
No offense taken Jon. Computers are great in some ways & horrible in other ways.
In the old days of non computer cars they were much easier to diognose & cheaper to repair. Now with all the sensors you either have to have a reader or deep pockets to pay a shop to peform the work.
Then if you had a miss it was most likely plug wires or plugs. Now it could be several different things.
What I hate worse than EFI is DIS. Cap & rotar arond $20. Coil Packs $160-200 a set :fire:
cap and rotor gets replaced every coupld years, coil packs last the life of the engine :)
plus we have junk yards.
The computer is very good at diagnosing the issue itself if you know how to read it.
Fuel pressure, spark, and compression tests are still basically the same.
But I do understand and get your point for sure, when you have 3 + wires under your hood and 4 vacuum lines it sure was alot easier to eliminate issues!! hahaha
now a broken coil wire or injector can cause you headaches for months....
Well that was fun
First, an upside down IAC valve gives you a really smooth idle, problem is that idle is around 2200 rpms.
Ok on to the good stuff
This adjuster plate lets you completely bypass the IAC, while leaving it plugged in, I guess is the good thing.
I closed the IAC port on Throttle body completely, and used the bypass plate screws to bring idle down to 1100 rpms in neutral.
When shifted into gear, something is still bringing idle up a bit, it hangs at about 1400 for a second when shifted back to park.
Also, the surging still occurs, even when IAC is completey, and rolling idle still hangs at 2000 in neutral, until vehicle stops, at which time it immediately drops to normal. I did notice that the car has to be going at least 60 mph for a while to trigger this. A farmer was going 50 with me behind, didn't surge when we appraoched the curve, as it would do normally if i was going 60
65 mph. cruising 2000+ rpm's seems to set it off.
I know I need a tune, and am budgeting for it. In the meantime, I shall play with collecting data???
That plate looks cool!! I polished it, now I need a throttle body spacer to go with it :D
after the throttle body spacer you will have every single bolt on known to man I believe
Wait do you have the intake spacer?
1" Phenolic resin -- it is a good thing.
There are no more bolt on's in the near future.
All effort will be directed toward this problem by pushing buttons. I hope
Update
I have worked a swap with a gentleman from a mustang forum, he is sending me a set of 30lb injectioners and the matched pro-m maf. He is going s/c so needs this larger stuff. As soon as it arrives, I will swap them and at least take care of that worry.
I sent BLK MK8 a 96 PCM to fix a problem he was having in a 5.0L conversion into a Miata hahaha the 98 computer he was trying to use wouldnt let them get around the PATS. Apparently it worked!
I plan to buy my tuner from him, if he is still selling them.
Well
I made a larger diameter intake tube today, actually I made it earlier, installed it today. It is quite a bit larger in diameter, I wonder if the previous one was too small. I will road test at high speed tomorrow. Initial in town driving was a bit different. Seems to rev better under load.
I lost about 1/2 inch of vacuum, so the 2.75" was a restriction.it would slide inside the maf and throttle body, wheras this new tube matches the maf, and is a bit larger than Throttle body.
You may wonder why I had such a small tube in the first place. :confused:
Hey, I was wanting more vacuum. :D
jtsmith said:
Well
JTSmith - Forgive me cuss I haven't read the entire thread but are you sure you don't have a vacuum leak of some sort? I saw the video you had posted on another site and it sure sounds like it. That and when was it that you re-set the computer? 100 miles, 200...ect. ?
Yeah, I am DAMM sure I don't have a vacuum leak.
I do have a x-cam though, and from what I am told, 16-17 lbs of vacuum is pretty darn good.
Just completed a round trip of 334 miles which required no reset, Torque converter remained normal, although I drove very defensively to avoid the situation which causes the surging. ( complete removal of throttle from cruising speed)
Consumed 15.9 gallons of fuel.
Well hell, It actually sounds good! I know that's bugging you but it's really not to bad eh?
Sort of weird little problem.
How about this? (just helping you think here) have you did the throttle action at the TB inself just to make sure it's not binding up just a bit? Maybe help it back after the rev and see if it still does it? If that's not it I'm not sure.
Thanks,
you are thinking for me I can tell
I rode with a voltmeter hooked to it to be sure lol, but good looking out.
here is another hint, watch how my maf-tuner drops to the idle band when idle comes down--which is first, the chicken or the egg?
Adjusting the first knob will cause the surging to stop
http://media.putfile.com/hanging-idle
jtsmith said:
Thanks,
I have a solution for you! Add a turbo?
scantool should be there soon....hopefully it will tell the tale
I am very glad to read that.
Thanks J.
Bad and good news ( I hope)
I am knocking on wood when I say this, but yesterday I cleaned my maf sensor again. Then, I adjusted my TPS , this time to .98v,
Low and behold, after 2 trips to Chanute and back, not 1 surge!!
My wife asked what was wrong, lol, why it didn't surge at the railroad crossing, as it always does.
Her last words about it " I don't think it is fixed" :frustrate
Well, after 10 highway speed to 30 mph decelerations, everything is good.
now about this stupid rev limiter
OK the bad
It is a bad processor in the laptop.
Now I am getting one of those--
