Thallarsen
- February 21, 2000
- Potomac, Maryland
- '99 5.0 Limited AWD
Stock '99 5.0 Limited AWD with over 200k.
After replacing a broken d/s sway bar link several months ago, I decided that it was time to tighten up the front end (200k+, it was time to give the steering/suspension components a little attention).
As I figured, the upper and lower balljoints were pretty sloppy. The outer tie rod ends weren't bad, but while I was in there, I figured they could use replacement as well.
After replacing both sides' upper/lower balljoints and outer tie rod ends, and getting an alignment, it's tighter, but still has a bit of a loose 'clunk' over bumps. Similar sound/feeling that the broken sway bar link made, but not as severe. Minimal play in the steering, so it's nice and tight.
They are the original shocks, and I'm considering them to be the culprit, but is there anything else that I should look at?
Re: shocks for the AWD with the rear load leveling system-
Are replacement shocks unique to this system and therefore pricey?
Thanks in advance,
J.P.
Thanks in advance,
J.P.
