guess i can update
That Sucks about your stuff, I am getting a Low pinion HD D44 (Ford) later this week, getting it pretty cheap, just gonna get it to have for future use. But i am looking for a ford 60, but not "Looking" to really spend anything on it.
well i stuffed my beat to hell fenders back on it, and took it to DAds mud bog yesterday. Did poorly, but after reveiwing the video i noticed that my RF tire was not powered. So i took it apart today and found the RF hub to be bad. Must have broken it at OSTC/Spring Fling, and didn't know it. Why couldn't the LF hub fail instead of breaking my yukon damn it.
Was invited to another local clubs event.......
heres some vid (9 minutes long)
http://youtube.com/watch?v=pJAEkqJXLrA
I won two solid diff covers (Gift Certs) in a raffle they held during the event SCORE!!!!!!! spent $40 in gas towing, $15 entrance fee and won $240 in merchandise. Its awesome, cause i was planing on buying a pair of covers for the B2 and just didn't have the money to spend.
I am thinking i may push my front axle another inch forward from where its at now, my pitman arm is kinda close to my drag link and i could use another inch further forward on my front driveshaft.
one of two i recently won in a raffle
i actually had to take a hammer and chisel to the cover in this area to be able to get at the bolts. The cover was bent over the bolts from draggin across the rocks.
New cover installed
went and got a non-a/c heater box. On the RBV's of this style the only difference in the box's themselves is in the engine compartment. And they interchange completely. The firewall is the same with or without A/C.
Changed my soft up a little bit, before it was open at the bottom on the sides, and it hung way over on the back. Now it hangs down just far enough on the sides and barely over hangs the back
been wheeling the last few trips with no inner fenders, been making a real mess of my engine compartment. Remedied that today.
newest addtion to the truck, replaced my junk champion 8K winch
went and got a warn m8000
he had it on ebay and the bids were up to $223 and it still had 5 days left. I noticed he was out of lansing, mi (50 miles from me). So i sent him a message stating i would come and get it today with cash for $275. He got back with me and said sure. So i went and got it. Seems to work fine. The cable that was on it was junk. But i have a pretty much new cable (the one in the pic). It seems to work fine i spooled the cable onto it and the winch never hesitated and never even felt warm to the touch. Atleast now i know i can get parts for it just about anywhere unlike my old champion.
mounted the solenoid pack, yeah its upside down but it'll have to do for now. Eventually i might relocate it to inside the cab of the truck. Its hard to tell in the pic but the box is mounted flush with the grill, so looking from the side you can't see it.
pics of the before after of the 63" chevy spring swap.......I retained the same lift height before/after
before
after
*the area of the front spring mount where i cut the bolt hole off is welded to the steel plate, you just can't see the weld in the picture. Whats not seen in the pic is the L Bracket on the back side of that steel plate that connects to the bottom of the frame rail and has peices of metal going from the bottom of the plate to the frame ral sideways as a cross brace/bridge.
*those are stock 89 rear 4wd chevy leafs from a 4x4 truck, the only modification to the springs is i cut the over load. The over load is still there its just no wider/longer then the spring perch.
