- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
I dont quite understand the logic of this setup. Theres no return to bleed off pressure, and the regulator is not upstream of the injectors (5 before, 3 after). The only thing I can see is that the pressure of the 3 after the regulator is regulated, but in turn reducing the pressure to those 3 injectors would relieve upstream pressure...
SVT
It sounds like the tank relief valve is doing the real work, and the vacuum line may be adjusting the pressure a little. I hadn't looked at the spare fuel rail I have in ages, are some injectors really down stream from the regulator?
The old style made more sense, because the regulator could control the pressure to all of them by relieving the extra pressure.
