I used the 31173 I believe, with the inline hose adapter. Instead of hooking up the AC input, I installed a rocker switch (being that my AC is part of the CanBus anyway.)
I flip the switch when I push the AC button (non freeway) or when at a light or stop and go traffic.
What I found without the manual switch, is that the fan would come on, get the temp in check then turn off. Within 30 seconds or so it'd come back on then repeat. In Sac, this will be a common occurance and put a strain on the system. A manual switch is needed IMO.
Most fans have a built in sensor that rests against the radiator. This "sensor" or resister actually limits the power to the fan causing the lower speed. High speed just bypasses the resister. If you remove these resisters, both power wires supply full speed. The resister also allows for a "soft start" and when full speed is needed, there's no in rush spike.
Google the electric fan Volvo conversion. (
Here) It uses the fan relays off certain Volvos (double relay setup and a water sensor off a BMW. The BMW sensor is designed to send two signals. One at like 195° (low speed) and one at say 205°. Only issue is mounting the BMW sensor. Some older Saabs came with a lower radiator hose adapter that has a bung that fits these sensors, but this adapter is impossible to find.
