As a new XSport owner, may I ask what motivated you to change the PTU oil at only 16K miles? Is this a known issue? Just curious. BTW, nice write up! Thanks for sharing.
Yes the PTU oil is an issue. A huge one. A glaring one. Just look at the metal sheen in the oil I dropped at only 16,000 miles. Ford says this oil is a lifetime fluid and does not need maintenance, but at 16,000 miles my drain plug magnet is saturated with metal along with the oil. Ford says "Lifetime" which begs the question, how long is a lifetime? Much speculation that lifetime means 36,001 miles. It is well documented that folks at 30,000 miles plus have drained only to get black sludge. One gent had his oil analysis come back and say his oil was on the verge of becoming abrasive. Do some searches on "Ford PTU Oil Analysis" or "Ford PTU Failure" and you'll come up with a myriad of articles. It becomes clear that Ford is taking a poor position on this and why those of us in the know should do the maintenance Ford isn't.
Lastly, I'm just happy Ford gave us the option to drain it. Could you image if the PTU was designed without a drain plug at all?
Big failures in previous years with 16/17 models getting a redesign, there is already a thread on that update.
Please link the thread that the 2016/17 had a PTU redesign. Thanks
So can you upgrade the PTU oil to a higher quality synthetic like Mobile1 or is the OEM already just as good so stay OEM?
Would a 13 Explorer Sport have a drain plug?
I went to a dealer near me and he told me that Ford does not allow them to chain the fluid, but he would point me to someone that would install a fill plug.
Which way is the drain plug facing? ThanksYeah, it's unfortunate, Ford doesn't want to touch the PTU's (I've seen some dealers that will) but Ford will happily change them after they fail. To address your question specifically, I don't recall on the 13's. You may have to get under there and take a look at it. There were many PTU's around that year that only had a fill hole around mid-way up the PTU. So the technique guys were using was to pump it out then pump clean oil back in.
No problem. Toward the passenger side.Which way is the drain plug facing? Thanks
Good job! I wonder if my fluid extractor will work on the PTU nipple. Sometimes there's internals in the way in getting to the bottom of the case for a full extraction, but if I can it works great.
Does the 2014 PTU have the rubber vent tube?
Should I be able to see the vent tube with cap from the top? I have looked around, took off air cleaner assembly to gain better visibility and do not see anything.Yes it does but may be a different internal diameter. Checkout the first video at the top of the thread.
Let us know how it goes! You have to crawl back further than you'd think to see up around the PTU. I'd put the truck on ramps and use a creeper if you have one.Absolutely AWD, and yes I watched the video. I will crawl underneath and see what I can find, thanks.
I have an early build 2014, built in October 2013 and the drain plug is half way up the case, not at the bottom. Explains why I could not find the vent hose. I guess I am left with getting a vac system and then pump the oil back in. Not sure which is more of a PIA but that's the story.
