- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
The 4.0 SOHC is a quality motor, that is why you still see plenty of 2nd 3rd and 4th gen explorers on the road most of them 4.0 equipped not to mention rangers and sport tracs(granted you take extra care of the motor). Ive got 295,000 on my original motor, never had to open the motor, haven't even replaced any of the timing drive yet. Ive only had to replace most of my engine gaskets with the exception of head gaskets and block cradle gasket. I supercharged it around 200,000 and its still runnin strong and I am currently working on building a 4.0 to 4.3 or 4.4 stroked and m112 blown V6 and also building a performance 5R55E. Id like to see somebody with a highlander or land cruiser say the same. I wont include Honda pilot in that because I know that thing wont make it that far. Although I will say based on the quick bit of research I just did the land cruiser does seem to have a beefier chassis frame. but the highlander and land cruiser and pilot are unfubugly. Explorers look so much better. Plus if you wanna talk vehicles outside the ones mentioned Ford alone definatly takes the cake in build quality compared to Toyota and Honda.
But as far as this rocker panel build goes he did do a decent job even though its not structurally sound but its prolly not worse then some of the rusted to hell rocker panels ive seen on our explorers. He still does have the option to do some spot welds. He could go to harbor freight and grab their cheap spot welder and do his spot welds. If it were me I would definatly adhere it to the forward section of the front door jamb and the rear section of the rear door jamb and the B-pillar and most likely even the bottom of the door jambs and then spot weld to the underside pinch weld and spot weld under the sill plates. I really really wish I could find rocker panel replacements like this for my 2001 explorer sport 2dr. All I can find are the stupid slip on knockoffs. If anybody knows where I can get the official rocker panel replacements I would greatly appreciate it. Or even if somebody down south is willing to go to a junkyard and cut out rockers for me from an 01 to 03 sport Id pay decent money. I'm looking to have the full rockers cut at the floorpan up to the bottom of the door jambs. Ill post a picture illustrating kind of what I'm looking for.
You just need to get serious about finding a good donor truck, and crank up the sawzall.
I like adhesives for bonding two surfaces together, but as the OP did, there needs to be stronger connections like welding, or screws where it's not truly structural.
I overlapped and welded the floor area, but the rockers and pillars have multiple layers, and had to be butted together, welded along the seam.
