I havent been active here for awhile. But I am still here and lately have been reading up on threads about intercoolers. My sitiuation is somewhat different as I run a centrifugal S/C. My truck is running but not driveable. I have not had it down to the dyno to get it properly tuned. Money is not the main reason but does play a role. So I was lucky we had a mild winter and I could drive my little car around. Now I got my second wind and want to get the truck streetable. As the temps warm up I thought about different ways to cool my intake air charge. My tuner says a bypass valve should work and thats what I have but an intercooler is really my best choice. Even though I only run 5 lbs boost the air charge is hot. From my searching, I have limited choices. the intercooler has to be small. I found these but they are very expensive and I need to justify the cost.
http://www.pwrradiators.com/categories/intercoolers/air-to-water-barrel/
So I need to get it on the dyno and go from there. But I dont know if I need to intercool if I run such low boost. I would rather play it safe and do it right.
