Something w/ rabbits. 72.5 pages of BS | Page 12 | Ford Explorer Forums
...Just a thought but, could you use a first gen frame...:scratch:
Yeah I could but rectangular tubing is just easier to work with (and stronger) at this point. And it shouldnt take too long to make a frame, its just a rectangular thingamajig after all. Of course I say that now but it'll take me 2 weeks :)
My secret Santa sent me this little guy for the doubler
i hope you have been workin hard on this thing, the weather here in germantown has been great! :)
whered you get the center shaft? and what case is it for?
Ah I forgot the Ostman brothers were in town!
As for the center shaft, its for a 1350/1354 transfer case -- you know, the usual Explorer/Ranger transfer case. I got it from another user who did not need it anymore because he instead went with an already built doubler. But you can get any center shaft resplined to your specs -- shops like Moser will do it for you. More info at RRORC: http://www.rrorc.com/forums/showthread.php?t=21585. Actually if you're going to respline, read those few pages on RRORC because if you respline too far up, the center shaft becomes very weak cauz its hollow there -- where as if you respline further down, its solid and much stronger.
So that is the output shaft cut and resplined instead of mating the two together and welding?
What kind of adapter plate are you using and what does it measure. What does that shaft measure (also separate length of the splines would rawk/0
Yup, its the output shaft cut and resplined.
I have no measurements yet on the length of the doubler/adapter plate but the shaft's lenght is about 8" and its built to the specs of the main doubler mentioned in the RRORC link above. The splines are 1.5" long and this is the correct length (according to the RRORC thread). But to get the adapter's lenght, you just stack the doubler case on top of the normal case (with the shaft in between) and measure the gap -- that'll give you the length of the adapter plate (plus a small fraction because you dont want the doubler's shaft to jam in all the way).
If you want exact measurements, let me know and I'll go get my caliper.
As for the transfer case I'm going to use, I was going to use my backup manual 1354 but I'd rather not slice that up so I think I'm going to pull a manual 1350 from a junk yard Bronco since the 1350s are a lot more common than the 1354s.
I believe the front case has to be a 1350, rear can be either?
Yes yes, you are right -- I looked back at the RRORC site and the front has to be a 1350. Thanks for clearing that up before I sliced the 1354!
As always IZ you have a lot of $#!% going on all at once. I complemint you on your ability to get seamingly impossible tasks done in a short amount of time. Also youre attention to detail is outstanding.:thumbsup: Good luck.:D
I appreciate you're kind words! Hopefully, once its done, it wont just spontaneously fall apart on the trail :)
To-do list for this week in order to finish the new chassis by the end of next weekend (besides going to the All Ford Nats):
- remove gas tank
- remove body lift
- support body
- lower original chassis (release air shock pressure and plasma gouge rear springs?)
- slice up original chassis
Just gusset everything you should be good. And again good luck. I should get up and get cracking on mine but its the details that take so long that slow me down.
The plasma cutter made quick work of the rock sliders:
Then the gas tank was disconnected from the chassis:
I forgot to empty the gas tank before I started working on the vehicle and its 3/4 full -- pretty damn heavy.
Transfered the old gasoline to the Civic via the tank's internal pump and a car battery -- D-D-Danger Will Robinson:
Then removed the pump/sending unit assembly:
Since I dont think I'm going to use the old gauges, I took resistance measurements of the original sending unit -- looks to be maybe a 20-160 ohm unit (160=full):
Now for the million dollar question:
does anyone know which sensor this is:
This is what that sensor looks like removed:
Ouu okay thanks!
Are you planning on putting that fuel pump in a fuel cell?
Probably cauz I don't want to deal with fuel delivery incompatibilities (mostly just pressure and flow rate).
