So if you drive hard into the corners at bristol for 500 laps you should not have any extra edge wear, LOL.
Tire wear is not from a static condition of a vehicle. As weight is applied to the tires in uncountable conditions, rubber is worn off of the tires.
The best air pressure is that which gives even tire wear during the actual use of the vehicle. That means that my Father will never wear out the edges of tires, he drives too slow. While other people will always wear out the edges, they drive too fast in corners. If the alignment is bad, such as with way too much camber, no amount of air pressure will keep the inside edges from wearing out first.
Tire pressures should be different for every single driver and their vehicle. How each driver, tire, and vehicle is operated dictates proper tire pressures, not any odd method. Regards,
