- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
Depth check
Not nearly as deep mounting surface as the stockers
Making sure each on is pressed fully
Then you have to go through and seat all the springs
Make sure they are pushed all the way on to the back lip
Like this
The magic pliers are used to seat the springs. I love having the right tool for the job
All 16 on this side done
Time for new springs, spring cups and retainers
I have been asked “how do you install springs with the heads on?” Well Scott… carefully my friend!
With the spring compressor setup perfectly (had to do some bending of the tangs to get the angle just right) the spring and cup will actually collapse around the valve stem… so the valve just floats. All that is required iSight pressure from a screwdriver through the spark plug hole to keep the stem up tall enough so the retainers can be placed with a small magnet
Like this
