97Sandbox
- February 7, 2019
- Seward, NE
- 2000 Explorer Sport
What a day. There was no way to get at the front driver's side bolt with a saw blade so I decided to try drilling off the head from underneath. It mostly worked, but the hole gradually wandered off center as I stepped up the bits.
Once bigger bits weren't helping, I switched to the die grinder. It took a LOT of cutting and grinding, but I removed the bolt head without causing too much collateral damage.
Pulling the starter on the passenger's side was my best idea of the weekend. With the starter out, the sawzall made quick work of the inner bolt. The trans cooler lines weren't too in the way (can't wait to ditch those in the future).
So finally, the manifolds are off. I can't celebrate just yet, though -- there's still two broken bolts in the right head. One is broken flush unfortunately, I'm going to try to drill and extract that one. The other has 3/16" sticking out that I'll weld a nut onto. I'm just hoping my welder can reach, I may have to find a way to shimmy the Mounty over a few feet.
