- June 16, 2003
- Humboldt, KS
- 2000 Mounty
There are 2 for coolant temp. One for computer, and, one for gauge.Fixed the thermometer and compass, where is the sender for the temp, it seems to be off?
The gauge sender usually has one wire.
The "engine coolant temp sensor has 2.
For more accurate temp readings , a scangauge II works great. It also monitors trans temp with a digital readout, many more gauges inside. With it you know exactly what coolant temp is
Edit, I misread. The outside temp sensor is indeed behind the bumper.
In the summertime it may read high on occasionally from various heat soak conditions.
