How to: - 2011+ Grille Removal with pictures | Ford Explorer - Ford Ranger Forums - Serious Explorations
How to: 2011+ Grille Removal with pictures
Drako99
Edmonton, AB
2013 Explorer XLT
So after reading many many threads asking the same thing about how to remove the grill on a 2011+ Explorer I got the gist of it and tackled it myself.
I completed the plasti dip of my grill but forgot to take pictures along the way so I went back and removed the grill AGAIN and took some pictures along the way.
This is to help supplement the many other grill removal threads out there and I hope it helps.
Front Grille
Step 1 - Open Hood, get 10mm Socket and small flat screwdriver
Remove SEVEN (7) of the 10 mm bolts circled in GREEN and the TWO (2) push rivet fasteners circled in RED
The top plastic cover then should come off freely
Step 2 - VERY GENTLY pry the grille away from the engine compartment and tilt it forward to expose the FOUR (4) very tricky nuts (10mm). TWO (2) are near the middle, and are the easier of the 4. The other TWO (2) are down by the headlights and are VERY tricky/hard to remove
You can see the back side of the bolt, which has the nut on it, at the tips of my fingers. This is one of the center ones.
Just above the White pointer stick (very technical) is the back of the bolt showing the nut near the passenger side headlight.
Step 3 - Remove the grille
This can be very tricky so TAKE YOUR TIME
Seen here is the back of the grill, circled in RED are the FOUR (4) bolts that had the nuts on them. Circled in GREEN are the SIX (6) clips holding the bumper in place. Careful, I broke one doing this write up.
Grilel removed -
Reverse the process to reinstall,
Hope this helps!!!
Rick
Pumpkin Pilot
Staff member
Admin
Wayoutin, Aridzona
'93 XL Pumpkin Edition
Callsign
AB7FH
Drako, I just split your post off into it's own thread and made it a sticky post.
I also set you up with a 6 month Elite membership for your very informative article.:thumbsup:
nrochwal
2013 explorer
Turned out awesome!
How many cans of plastidip did you use on the grille? Did you use the glossifier?
Drako99
Edmonton, AB
2013 Explorer XLT
I used 1.5 cans. No glossifier
MikeCallery
'11 XLT Tri-Coat
Great article on removing the grille, thank you.
I am wondering if anyone has ever played with the air intake and what the implications would be of enlarging it?
Mondak
Carlsbad, CA
2013 Explorer XLT 4wd
This is fantastic. Any information about the plastidip process itself you want to impart?
Either way, great work.
Zach7
Great NW
2012 Ford Explorer XLT
Great post and pictures for this removal. Thanks!
RandyH2
MI
'11 Limited AWD
Great post. Thanks for taking the time!
mmartin028
Nashville, TN
2015 Explorer XLT
Thanks for the write up and the photos.
I want to plastidip the grille without taking it off. After removing the top screws and the plastic piece, is it possible to pull the grille forward enough to put a piece of cardboard or something to block the radiator from being painted while painting the grille?
Hughhefnerjr
Brooklyn, NY
2016 Ford Explorer XLT
How do this work out for you? I'm thinking of doing the same with my 2016. Getting in there to remove those nuts is difficult and you're sure to break at least one clip attempting removal.
Scarey118
Phila, PA
2012 Explorer Limited
Any update on plastidipping without taking the grill all the way off? I just bought a few cans last night to do the chrome explorer on the back and the grill
mmartin028
Nashville, TN
2015 Explorer XLT
Yes, you can plastidip your grille without taking it off.
Just remove the 7 bolts and 2 plastic fasteners (shown on step one above) and gently pull the grill forward. It will give you enough room to put some paper or cardboard between the inside of the grille and the radiator.
I used a few coats of glossifier to get the shine.
kaotikgood
Most Interesting Man-Child in the World
Arlington, Texas
2016 Ford Explorer Sport
Callsign
Whiskey Tango Foxtrot
Very useful!
I will be doing this on a 2016 this afternoon and will take picture for picture if you would like to add them under each of yours to include the 2016 - 2017 models. I'm sure the differences are subtle at worst but I love me some pictures!
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Very useful!
As an Elite member, thank you by the way, you can post pictures right from your computer and some devices (I think) by using the "Upload a File" feature.
mrnavy2
Location
Central New Jersey
Central New Jersey
2018 Ford Explorer XLT
I want to also do mine and the 2 chrome strips
peterk9
Staff member
Moderator
Callsign
VE3
Did mine today
Looks great. I'm a big fan of leaving the chrome strips the way they are. Another member did the same thing quite a while ago. I think it's much 'richer' looking then full black.
