2013 PIU Keyless Access Issue | Ford Explorer - Ford Ranger Forums - Serious Explorations
DanFi
McDonald
2013 Ford Utility base
Hello just purchased a 2013 Ford PiU Base
I changed these with forscan
720-01-03 - Change to --- 808A 0000 35
726-18-01 - Change to --- 0100 0005 4C
Got all the way to program my fob 7x off 8x on(on and off 7 times with 8 time in on position) the keys cycle but doesnt does let me pair remote..
Any ideas what I did wrong? I also installed hood sensor.
Thank you all.. cant wait to be a productive member of this forum
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Welcome to the Forum Dan. :wave:
Did you mean to say the locks cycle? I'm not sure if a Base Explorer can be programmed for Keyless Access or not. Did you get the programming changes from a FORScan spreadsheet?
DanFi
McDonald
Yes Sir I did.. Except it wont Take B5 had only 35
Just to Confirm its a 2013 Ford PI Utility Base AWD
peterk9
Staff member
Moderator
Callsign
VE3
Yes, I'm aware. It's also in the your margin profile. ;) Perhaps it just can't be programmed for keyless access.
medic550
Somewhere
2015 PIU
Do you have the plate at the bottom of the dash in center with cigarette plugs? Mine was missing from my vehicle and i could put in program mode but there is an antenna receiver behind that panel that is what receives the keyless and TPMS sensors.
DanFi
McDonald
Can you take a picture? I'll take one of mine.. I have thr cigarette outlets 2 of them..
DanFi
McDonald
Yes.. I think that maybe it.. should there be this part
On the floorboard in between the seats near the console? Part # BB5Z15K602K
medic550
Somewhere
2015 PIU
This is the part that goes behind the panel with the cig plugs. It could be unplugged.
you have to take the panel off. It plugs in behind it.
DanFi
McDonald
Thanks I think I see the plug covered in tape on the corner of that picture.
Again thank you so much for something new to troubleshoot.. I definitely appreciate it. I was spinning my wheels
Update: I felt under the plastic dash and its unplugged.. going to take dash apart tomorrow and find the plug..
DanFi
McDonald
Thank you so much.. 5 days of spinning my wheels and you help out and 10 mins and its fixed
16vcabman
Ortonville
2017 PIU
Di
Did you hit the unlock on the door panel first? That tells the computer to go into program fob mode along with the ignition switch on and off?
DanFi
McDonald
Di
Yup..the antenna was unplugged had to plug it in
jmenende
San Juan, P.R.
2015 Explorer PIU 3.7L
Could you give me more detail. I have the exact same issue. My fobs wont program even after the locks cycle. You say there is a connector behind the panel with the two cigarette lighters that needs to be connected to what module. Please advise. Thanks
