22" Wheels For Explorer
mabupa
florida
2013 explorer limited
Oh ok. I thought the 20s were just an option for Limiteds. Well thats great then if someone has weighed those 20s, it would be a bit closer to what the 20" Sport wheels weigh. I think I've read every thread on here about wheels, some multiple times by accident. I've spent an inordinate amount of time on here. I love the wealth of information people provide with forums... I just wish there was an easy way to organize that info.
I put 22s on my limited and SOLD the 20's. When I shipped them it was 71 pounds per rim. That's with the tires and sensors mounted and they only had 1000 miles so, no wear on the tires. Mine came with hankooks.
I forgot to weight the new setup before I put them on.
Bstollmaier
Cincinnati, OH
2013 Explorer Limited
Correct, the limited had 20's. Road noise is slightly more but nothing annoying. Exhaust is louder ;) Never weighed either.
LakersCentral
Southern California
2014 Explorer Sport
Thanks! thats super helpful info :). Mind me askin what you sold all of it for?
ps. I wonder if the Sport 20s weigh more or less than the Limited's. Anyone have any guesses?
mabupa
florida
Thanks! thats super helpful info :). Mind me askin what you sold all of it for? ps. I wonder if the Sport 20s weigh more or less than the Limited's. Anyone have any guesses?
I SOLD them for $1200.00. That's shipping included.
ARS1
Tampa, Florida
'14 XLT Platinum White
Wow that looks good but damn you must have had a tight butt pucker cutting into those fenders like that!!!
SkrApUNB
Louisiana
2003 E46 - 2014 Explorer
beautiful truck OP. Definitely looking into a few different things for the wifey's RR.
morfhious3
lansdale ,pa
2014 Ex sport
whats the sardina wheels offset?whats XSport factory wheel offset anyway?
baddceo
OP, KS
2011 Explorer LIM 4WD
Sport wheels are 1/2 wider than limited 20's so I am guessing heavier since more metal. The only way you are going to lighten unsprung weight on a 22" setup is to get forged wheels which usually aren't cheap or find a wheel with a very thin spoke and less of them to cut down on volume.
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve
Callsign
VE3
Both the Limited and Sport come standard with the same 255/50R20 tires. The Sport does have an optional 265/45ZR20 Summer tire that you can order.
LakersCentral
Southern California
2014 Explorer Sport
So the Limited's rims are 8.5" wide? Cause the Sports are 9". I'm assuming the "Summer package" is merely a change of the tire size, not the rim width, and thus not increasing the weight of the rim (and possibly slightly reducing the overall weight by using a smaller tire).
I was looking at all sorts of rim types. 3-Piece rims were about twice as much, and thus out of the question. But I did find some that weren't as beefy as the Sport rims (I didn't like that look anyway).
I measured the stock Sport wheels when they took them off: 70.8 lbs (right on target with the estimate mabupa provided from his Limiteds). I then measured the new (22") wheels I got right before they were mounted: 71.6 lbs. Even though the rims and tires by themselves were lighter than the stock by a few pounds, I hadn't take the compressed air into account. :banghead:
Interestingly enough, the 265/45/22 wheel setup i have now makes the standing height 30.35" (1% bigger than stock). And my new wheels are 1% heavier. So inch for inch, I am running almost exactly the same as stock. haha
zannism3
BAYSIDE NY
2014 FORD EXPLORER SPORT
Looking good brother
morfhious3
lansdale ,pa
2014 Ex sport
was wondering if you could run staggered rims on the x sport and make it up on the tire size?like 20x9 on front and 22x10 on rear?
peterk9
Staff member
Moderator
Callsign
VE3
I think that may play havoc with the AWD system.
morfhious3
lansdale ,pa
2014 Ex sport
thats what theyve been doing on the evo x and the lexus is250 awd. when they run staggered wheels and different tire size to balance it out, but of course they are all sedans not cuv.
peterk9
Staff member
Moderator
Callsign
VE3
I guess it would also make it impossible to correctly rotate the tires.
baddceo
OP, KS
Those sedans are staggered from the factory so I presume they are designed to work with thier AWD systems. I am in the process of test fitting 22x10.5 all around and will post once I confirm. Got my tire to test fit 285/35/22 its a beast.
morfhious3
lansdale ,pa
2014 Ex sport
yes we cant rotate them.evo x come stock 18x8.5 all way around as far as i could remember when i had it 3 years ago and the Is250 was 17x8 all way around also.then saved my volks and installed it on my lexus Is and i was running 18x9.5 front and 18x10 on rear with 245 on front and 265 on rear on both cars with no problems.i will try to find the discussion thread of this on the evo or lexus forums.
morfhious3
lansdale ,pa
2014 Ex sport
this is from the clublexus forum running staggered on a Is 250 awd:
- What is your exact wheel/tire setup ?
F - 19x8.5 Face-1 35mm offset. Toyo Proxes T1-R 235/35/19
R - 19x9.5 Face-2 36mm offset. Toyo Proxes T1-R 265/30/19
Dropped on Eibach springs for IS350
- How many miles you've been running this for ?
10,000 miles
- Are you noticing any issues (gas millage ect...)
No problem so far... gas mileage is about the same
- Also post your general thoughts/comments
The wheels diameter is less than 1% difference so I don't think there would be any problem
all you have to do is keep the overall rolling diameters within 1/4" of eachother and the Traction control will do the rest. 1010tires has a good calculator that I use to calculate mounted diameter to validate a AWD staggered setup.
baddceo
OP, KS
A Little Preview of my 22x10.5 Test Fit
So the car is dirty and of course it's not settled after being jacked up so pay no attention to the gap it doesn't sit that high. All I have to say in my opinion is perfect. They look bada$$ and I mean all together blew me away. Tested back and front, fit's perfect, about 1/2 inch or less poke. Deep concave with 285/35/22. Offset is 28 and the package weighs 75lbs I couldn't be happier. I started out thinking I wanted the polished lip version but this looks so much better. I ordered the remaining 3 rims, tires and black lugs. Mighty happy can you tell...
13Sport
Los Angeles, CA
2015 Explorer Sport
Would love to see it off lift, and know if there are rubbing issues.. it looks like it's gonna be a little tight on turn.
L 18 mustang wheels on 17 explorer Modified 2011- 2019 Explorers - Tuning & Mods 4
T 13 SHO wheels on explorer sport Modified 2011- 2019 Explorers - Tuning & Mods 10
W 2013 Explorer Sport with Aftermarket Wheels and Tinted Windows Modified 2011- 2019 Explorers - Tuning & Mods 3
V 20x11 +35 wheels on 2019 Sport Modified 2011- 2019 Explorers - Tuning & Mods 3
B Different options for center caps on 2016 sport wheels? Modified 2011- 2019 Explorers - Tuning & Mods 9
F HI! I need help with Wheels and Tires!* 2017 Modified 2011- 2019 Explorers - Tuning & Mods 0
T Part number/alternate options for PI black wheels? Modified 2011- 2019 Explorers - Tuning & Mods 5
M Has anyone plasti dip the Police center caps - steel wheels Modified 2011- 2019 Explorers - Tuning & Mods 3
M forgiato wheels Modified 2011- 2019 Explorers - Tuning & Mods 2
J New wheels Modified 2011- 2019 Explorers - Tuning & Mods 1
X 17" OEM Wheels Questions Modified 2011- 2019 Explorers - Tuning & Mods 12
E Sandblasting Wheels Modified 2011- 2019 Explorers - Tuning & Mods 2
X Wheels TSW Bardo Modified 2011- 2019 Explorers - Tuning & Mods 2
C 2015 Wheels Modified 2011- 2019 Explorers - Tuning & Mods 1
W Sport wheels/grill on XLT? Modified 2011- 2019 Explorers - Tuning & Mods 21
W Does anyone have Any Pics of A/T tires on 20 or 22 wheels? Modified 2011- 2019 Explorers - Tuning & Mods 17
K 22 inch wheels with HR Springs!! post here Modified 2011- 2019 Explorers - Tuning & Mods 1
R Interceptor hubcaps on 17" base wheels Modified 2011- 2019 Explorers - Tuning & Mods 6
S Powder Coating Rims / Wheels Modified 2011- 2019 Explorers - Tuning & Mods 14
K New 22 inch wheels-storm trooper ex Modified 2011- 2019 Explorers - Tuning & Mods 9
S Has anybody ran 20 x 10 wheels on a 2011-up? Modified 2011- 2019 Explorers - Tuning & Mods 2
BAD430BENZ Painted Wheels installed.....finally ! Modified 2011- 2019 Explorers - Tuning & Mods 15
I Need to know offset and backspacing of sport wheels Modified 2011- 2019 Explorers - Tuning & Mods 2
B Advice on what wheels to get for 2014 white limited. Modified 2011- 2019 Explorers - Tuning & Mods 5
H Larger Tires on OEM & Aftermarket Wheels Modified 2011- 2019 Explorers - Tuning & Mods 124
M Wheels-2012 xlt Modified 2011- 2019 Explorers - Tuning & Mods 3
G P/c or Plastidip wheels Modified 2011- 2019 Explorers - Tuning & Mods 0
R Plasti Dipped Wheels Modified 2011- 2019 Explorers - Tuning & Mods 53
W Winter or Summer Wheels/Tires Storage!! Modified 2011- 2019 Explorers - Tuning & Mods 2
R Plasti dipped stock wheels and chrome pieces/HID fogs installed Modified 2011- 2019 Explorers - Tuning & Mods 31
M Plasti Dip Wheels + Puddle LED Install Modified 2011- 2019 Explorers - Tuning & Mods 53
2 pics of 17 inch Wheels and tires Modified 2011- 2019 Explorers - Tuning & Mods 0
bodybump New Wheels!! Pics Loaded Modified 2011- 2019 Explorers - Tuning & Mods 25
bodybump Which Wheels?? Modified 2011- 2019 Explorers - Tuning & Mods 4
D Thoughts on staggered wheels? Modified 2011- 2019 Explorers - Tuning & Mods 4
H Aftermarket wheels Modified 2011- 2019 Explorers - Tuning & Mods 752
C 2019 Explorer Sport Speaker Install/Discussion Modified 2011- 2019 Explorers - Tuning & Mods 1
J 2014 Explorer Audio Modification. Modified 2011- 2019 Explorers - Tuning & Mods 1
D 2016 explorer leveling kit Modified 2011- 2019 Explorers - Tuning & Mods 0
are6rider 2015 Ford Explorer Stock Speaker Upgrade - Sony System Modified 2011- 2019 Explorers - Tuning & Mods 20
J Hide wooden trim in explorer? Modified 2011- 2019 Explorers - Tuning & Mods 2
J Tow/Haul Mode 2011 Explorer without tow package Modified 2011- 2019 Explorers - Tuning & Mods 3
G Installation of Power running boards on my ford explorer 2015 XLT Modified 2011- 2019 Explorers - Tuning & Mods 4
TJ@Steeda Steeda New Product Release: Steeda F-150/Explorer Pro-Flow Blow-Off Valve Adapter (2011-2019) Modified 2011- 2019 Explorers - Tuning & Mods 1
C Explorer sport 9006/9012 upgrade Modified 2011- 2019 Explorers - Tuning & Mods 2
J Issues with FORScan in 2018 Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 21
TJ@Steeda Now Available: Steeda Explorer Adjustable Toe Links Modified 2011- 2019 Explorers - Tuning & Mods 10
M Headlight/Fog light upgrade for 2015 Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 24
M 2018 Explorer Speaker Install Modified 2011- 2019 Explorers - Tuning & Mods 37
9 2016 Explorer Sport Downpipes or Borla Catback Modified 2011- 2019 Explorers - Tuning & Mods 2
Similar threads
