3800 M90 Build | Page 4 | Ford Explorer Forums
3800 M90 Build
They are 18.5lb .they go by flow rate;)
I just figured that out. Sorry. I lead you down the garden path. Sounds like I with throw these ones away. They obviously won't work for anything any of us will be doing.
All good.thanks for the offer tho;)
I was instructed by my tuner to reuse the housing from my granatelli mass airflow sensor by to use a stock sensor. From there they dialed things in with a Diablo Sport MAF Extender......never did get they air/fuel ratio and also I'm not going back to those guys cause they claimed they couldn't come up with more tunes than an emissions tune and a normal driving tune........pissed me off cause my chip takes up to 4 tunes, when the winter is over I'm gonna send my chip over to fishy's tuner<---this guy almost has our same setup just a lil never and is putting out more power than me, but then again he also upgraded to 42lb injectors last I heard without a cat!
The Diablo sport maf extender adjusts the voltage that your maf is send and taking in so it doesn't max out to early or too late!
what size is the housing?you still have ob 1 right?what chip are you using?yea ive been following his thread here and over on rpm,his numbers seem fishy personally and 42 is way to big for the amount of boost he is running.he said he was running 30lbs NA witch even with a tune should flood our motors:rolleyes:
ok wow so been doing some reading and looks like if i had the maf calibrated to its size and injector size i probably get away with stock ecm for a bit till i could get it in to really tweek it.also 24lbs injectors i would say would be fine for the hp our motors put out even with FI,i would think anything over 30lb would just be too much.also anyone that is running a larger maf on there 4.0 should get a new sample tube for sure.im going to email them and get a tube for my 70mm maf and 30lb injectors.good read
http://www.cnlperformance.com/MAF_info3.html
Let's use another example. This time for 30lb injectors on the same 1989-1993 Mustang 5.0:
19lb calibration vs 30lb
As you can see in this example, the 30lb injector calibration is much higher "vertically" on the graph, as it requires a higher level of airflow to achieve the same voltage output. In this particular application, a 76mm upgrade MAF housing with a "Purple" coded calibration tube is utilized with a conical filter mounted directly on the end of the MAF housing. This calibration requires 57.16% more airflow to achieve the 4.6 volt data point (as highlighted by the green vertical line) versus the "optimized" 19lb calibration. This calibration is almost "perfect", as when you divide 30 by 19, the result defines that the MAF calibration must require 57.8% more airflow to achieve the same air/fuel ratio as the optimized 19lb calibration does with the factory stock injectors. This means that your air/fuel ratio at 4.6 volts with 30lb fuel injectors will be within ONE PERCENT of the air/fuel ratio that is realized with the "optimized" 19lb calibration and factory 19lb fuel injectors.
Since your factory computer processor (without any custom tuning) still contains definitions for 19lb injectors and the stock factory mass airflow assembly (in the transfer function table), this is how ALL aftermarket mass airflow units are able to compensate for larger than stock injectors while still running the factory computer processor. Whether you use our calibration tube method, or if you have a unit that features a modified factory sensor, this is how you are able to upgrade the injector size without changing the computer programming. This is the way that it has ALWAYS been done, and this is the only way that the aftermarket has ever compensated for larger than stock fuel injectors with a factory stock processor in the Ford performance aftermarket. Even if you purchase a unit from another company that features a modified sensor, this is still what is taking place and is the method that is used to achieve a proper air/fuel ratio with larger fuel injectors and factory computer programming.
It is our belief that although the method of sending a re-calibrated MAF signal to the computer to adjust for larger injectors with the factory computer is tried-and-true, it does have its limitations. We believe that a re-calibrated MAF signal when used with a factory stock computer should only be utilized for up to 42lb injectors on vehicles that originally came equipped with 19lb or 24lb fuel injectors. As the injector size is increased, the MAF voltage output must be decreased at a given airflow rate. You reach a point at which the voltage must be reduced so much that it affects the quality of the signal at low airflow ranges such as idle. Once the voltage level goes below .5 volts it becomes very unstable (as mentioned before) because the sensor is most sensitive at low airflow rates and becomes less sensitive as the airflow rate increases and the signal output approaches 5 volts. This can be seen in all of the transfer function graphs provided on this page, as the graph ramps "upward" at an increasing rate as the output approaches the 5 volt level. As the injector size is increased, the MAF voltage output must continuously be lowered. All the while your computer processor STILL BELIEVES that you are running 19lb injectors and a factory stock mass airflow unit/calibration.
At a certain point, you are expecting far too much from the factory stock computer. When running large fuel injectors with custom tuning, you are able to re-define both the injectors installed with the ACTUAL injector slope values, as well as the corresponding MAF table for the ACTUAL mass airflow calibration that you are running on the vehicle. The result is a configuration that duplicates the programming and physical configuration that Ford would have utilized had your vehicle come from the factory with your same aftermarket MAF unit and installed fuel injectors. This results in a superior tune, and allows for high levels of power with the best drivability possible for your combination.
Although a lot of custom tuners do this by retrofitting newer MAF units (like the 2001-2004 Lightning or 2003-2004 Cobra assemblies) to older vehicle applications, the total "range" of these units will not support high levels of power, as their voltage output will exceed 4.99 volts at less than 500 rear wheel horsepower. This goes back to the fact that Ford chose the calibration for these applications based upon the maximum horsepower of the original application, with a certain amount of additional range to facilitate some typical modifications that would be performed to the vehicle (boost pulley upgrades, etc.) which would increase the MAF voltage output. In order to facilitate the needs of high horsepower 1989 to 2001 applications where large injectors and custom tuning is utilized, we have developed specific direct fit units that utilize a patented calibration method which provides the adequate range to meet or exceed the voltage range requirements of such applications. This will be expanded upon further in section 6: "Tuner Calibrations and Computer Tuning" .
Fuel Injector Size Considerations:
If you run a fuel injector that is much larger than what is needed for your application, then this will result in the computer processor not properly calculating load. This can lead to the computer delivering the wrong level of timing to the engine at various conditions, including wide open throttle. With the proper sized injector for your particular combination, your voltage output in a naturally aspirated arrangement will typically max out somewhere between 4.6 to 4.7 volts at wide open throttle at your maximum RPM level. The use of a "ram air" type system is not recommended, as it can cause the voltage value to become too high as a result of the sensor being exposed to (reading and reporting) more airflow to the computer than the engine is actually processing. This will be explained in detail in section 4: "How various factors affect a MAF calibration/signal" .
As a general rule, it takes .5 (or ½) pound of fuel per hour to generate one horsepower in a naturally aspirated application at a standard rated fuel pressure rate of 42 to 43 psi (roughly 3 times atmospheric pressure). To estimate your proper injector size, you can use the following formula:
Maximum Horsepower Estimate Divided by 2 (for ½ pound of fuel per hour to generate one HP) Divided by 8 (for number of injectors).
Using this formula, we will calculate the appropriate injector size for a 345 HP rated "crate engine" as: 345/2/8= 21.56 lb/hr. This means that a 24lb injector is more than capable of supporting the fuel requirements of a 345HP engine with 8 fuel injectors at a standard fuel pressure level at wide open throttle. If it were a 6 cylinder engine, the injectors would need to be larger (345/2/6 = 28.75 lb/hr) because there are two less fuel injectors available to deliver fuel. In such an application, a 30lb injector would be sufficient. For a V8 application, the following common injector sizes support up to the following horsepower levels:
19lb/hr: 304 HP
24lb/hr: 384 HP
30lb/hr: 480 HP
36lb/hr: 576 HP
42lb/hr: 640 HP*
*The most commonly utilized 42lb/hr injectors have an ACTUAL flow rate of 40lb/hr.
Since Supercharged or Turbocharged applications require a slightly richer air/fuel ratio, they need approximately 10% more fuel capacity than naturally aspirated applications. To estimate the HP capacity for each of the above injectors sizes in a forced induction application at a standard fuel pressure level (not using an FMU device), multiply the HP values by .9 to compensate for the additional fuel required.
Elevated fuel pressure levels will increase the maximum flow rate of the injector. The effects of this can be calculated as follows:
Raised Fuel Pressure Divided by Injector Rated fuel pressure equals percent difference of fuel pressure. Take the square root of this value and multiply it by the Rated Injector Size.
For example, if we take a 24lb rated fuel injector and run an FMU (fuel management unit) that elevates the fuel pressure under boost conditions to 65 psi, you would calculate the effective fuel injector flow rate by taking the maximum fuel pressure (65 psi) divided by the injector's rated fuel pressure (43 psi) to get a factor of 1.5116. You then take the square root of this number (1.2294) and multiply it with the original rated injector value of 24lb to get 29.507 lb/hr. This means that when the fuel pressure level on a set of 24lb rated fuel injectors reaches 65 psi, the effective flow rate (due to the increased pressure) becomes close to that of a 30 lb/hr injector at the standard 42-43 psi. This formula is universal, and can be used to calculate the flow rate changes for fuel injectors when adjustments are made with an adjustable fuel pressure regulator as well.
now im real lost because if thats all true then why do the Thunderbird Super Coupe 1989-1992 come with 30lbs and the newer model 93-95 comes in 36lbs?they only put out around 200hp,i should be near that without boost!!
http://www.cnlperformance.com/73mm_tbirdsc.html
Im guessing its all in the tune, and how hard you are going to drive the injectors. Probably a few schools of thought on this. It has to come down to what the guy doing the tuning recommends as something he can work with.
I agree that it only seems logical to use something that the factory tune see's as something within its calibration range and can adjust for.
That Diablo maf extender makes it sound like a person could do rough adjustments on their own using the readings from the O2 wideband and get close to the right sensor readings to work with larger injectors. I think you are on the right track with the 30's. That seems to be the common size for anyone making real power out of these motors.
also on a side note the stock ford mustang gt 87-93 70mm maf flows 815cfm vs the c&l "almost 800" maf
do we have low or high Resistance injectors?also would the ones from a tbird fit?think im going 36lbs now as that what the tbird uses and the gm 3800
Exactly...that's what I did with my truck and I had the stock ECM with no tuning at all...just a calibrated 80mm maf which was honestly bigger than i really needed. Anyway with that setup it didn't perform even close to its full potential but it was safe.
I'll see if I can dig up one of my old dyno sheets to show you the A/F
Im just lost when it comes to injector size.from what i can tell 28lb would be fine but why does a stock car use 30-36lb?i might have to do with the charger type.Idk but i would rather run rich and back off when tuned than buy to small of injectors and run lean or have no room for growth .how much hp was you putting down?
One more thing my truck runs lean now till wot.i run about 14-15 cruising and about 13.5 wot.from what i read you want anywhere from 11-12wot and 12-13 with FI.also what happens when it goes into close loop,like wot or maybe its open loop Idk but don't it go to a set number and stop using data.or does it not use anything but the O2 reading during wot
High impedance, same as the 30 or 36lb'ers in the SC. Yes they will fit.
BTW - The info you have is wrong. The 89-93 SC had 30lb'ers and the 94-95 had 36lb'ers. Not 89-92/ 93-95.
Sorry here at work right now.....my MAF from what I've read is the same as the pro am 70mm! and yeah I thought fishy numbers were way too high too, but with my big tires and rims I don't know what the difference the weight adds to the dyno. I have a SCT 5 programs flip chip and its been on their site for years now and I wonder how come nobody really talks much about it on here. Oh and I'm still OBD1, and the reason I really went with the 30's was because I came across somebody that just wanted $50 for all six.....other wise I probly would of just got 24lb injectors. But back to fishy....My tuner would only do 2 tunes for me leaving 3 other banks unused and empty so I'm gonna send my chip to his tuner as he said he can gey me more hp's and he said he will do it for $125 so why not try it....if I don't like them then just stick with my already existing tunes you know!!! Oh and to all who always ask I pushing 8psi on a centrigal paxton supercharger!
i wonder how his tuner is going to write you tunes with out you being on the dyno?unless he send you the tunes that he writes for fish but he has ob2 so those wouldnt even work.and he says he has stage three heads,but when it come to p+p every job is different,so it would even be smart to use his tunes if he was ob1.yea that the chip i was looking at to,or i was going to do a mega squirt but that chip would be way easier for sure.i got a tuner here but think he said he didnt have any of the software for an explorer.
so i cant just buy the sample tubes and put in my maf you have to use there maf.the thing is the list about four different colors for 36lbs injectors.like the 76mm maf 36lbs for different vehicles.i would figure all 36lbs injectors with a 76mm maf would use the same.the tbird even uses a different tube for its 76mm with 30lbs injectors.i would think the tbird with 36lbs would be very close to what a 4.0 m90 with 36lbs would use as they both are v6 and the hp is about the same.im going to have to call them and see what they say,got a feeling they are going to want me to use a custom maf and custom tube$$$$ :( might just wing it and go with a 76mm with 36lbs tbird maf
Ok just got off the phone with c&l and they are going to do a custom tune for my maf to match 36lb injectors .i got a c&l 76mm maf from ebay and 36lbs injectors.the only problem is he wants me to send him my electronics and my computer code to flow test and tune it.the problem is this is my dd for now so i need another maf electronics and where to find my code at.i also told him that i was running a 70mm now and he had me go over all my A/f ratios at different rpms and loads and basically said that it was messing thing up real bad for my motor and making me lose alot of power.he said he guarantees that after he matches the maf and injectors to my computers set standards that it will be safe and run just fine.he said i would still need a tune to fine tune the timing and a/f because of it being a built motor but should make tuning way easier.so anyone have a spare stock maf electronics and computer code?he wants $75 to tune it.
$70.00's Pretty cheap. Then add the cost of possible rush shipping each way. Ugh.
ODB1...is the computer code a 4 digit code inside your drivers door? I have no idea how one would read it with some kind of a code reader.
