SidCharming
- January 20, 2012
- Location
- Minneapolis, MN
- Minneapolis, MN
- 2012 Explorer Limted 3.5l
I'm pretty sure both will fit fine just preference
Hello everyone.I got a question about the Austek one. I know that the 4.0 L SOHC engine for before 7/24/2000 has a upper radiator hose outlet that is taller/ high angle then the ones, from after 7/24/2000. I bought a plastic one to get me by for awhile on my 2001 explorer sport that was made 9/1/2000, so it has the lower angle upper radiator hose outlet. Does the Austek have the lower angle upper part or the lower angle one?? I want a metal one to replace the 18 dollar one i bought. This photo shows it. On the left is the post 7/24/2000 low angle upper radiator hose outlet. On the right is the pre 7/24/2000 higher angle upper radiator hose outlet.
Thanks,
John
Looks to be an OHV.Hello everyone.
I have a douh. My trucks engine is 4.0 L 6 Cylinders OHV or soch? I have ada Explorer 2000 4 wd. I will send a picture.
I woul apreiciate it.
I'm very interested in the Simmons housing. Does anyone know the part numbers for the push in sensors? Also does anyone know the name of the hose under housing? I'm gonna do this mod and want to make sure I have everything before I start thanksI obtained 2 thermostat housings for my 2001 Ranger.
The original is plastic and not leaking yet but you know how that goes on the 4.0 SOHC.
The first one is from Simmons Autosports.
I have used theirs before and its a great part, way better than the original plastic one from Ford.
Here are some pictures of it.
View attachment 159610 View attachment 159612
Upper Thermostat Housing
View attachment 159613 View attachment 159625 View attachment 159626
Gaskets and Seals
View attachment 159627 View attachment 159628 View attachment 159629
