Now I don't want to sound like I'm some suspension guru, because I'm not. All my linked whether 4 or Radius arm has been limited to rear suspension only. Drag cars, some dirt Late models and my own 4x4s. With that said. The reason the vast majority of people run bushings in radius arm suspension just like I got in my rear, is not because their cheaper, but the way their designed.
Let's look at the pic above. It has a Ballistic joint in one of the link brackets. The center line of the bore is naturally parallel with the axle. The sides are 90 deg. or perpendicular to the axle.
The joint is designed for rotational, not lateral loads. This joint is maxed out about 20 deg. from it's perpendicular plane in the first pic. And it is now steel to steel. Now remember were talking radius arm not 4 link in my example. The sides are not hitting the side brackets but the built in spacers on each side. A none wristed radius arm acts like a sway bar and puts tremendous pressure on the sides of the bushings/joint. But the bushing has rubber at it's mating surface with the brackets cushioning the side or lateral loads and the has a steel sleeve that can also move inside the rubber/poly bushing. Now this may eat up the bushings but it's better then having steel to steel contact as you would with heims or joints which may even limit the articulation less then steel bushings with rubber/poly inserts. Not counting that you may just completely destroy the joint/heim.
Now with a true 4 link the joints normaly don't undergo such radical angles.
I got to admit this is a fun thread and a lot of different opinions just like I read on Pirate and many others regarding link vs radius arm suspension.
Got to admit that my rear outboard radius arm suspension in the locked mode with no sway bars will also out handle some cars thru the turns. But it's not worth a crap on trails untill I un-pin one side.
