rhauf
- November 1, 2005
- Ca
- 91,93,98,&02 Exploders
get a trans temp gauge so you can keep an eye on it.. and get a gigantic trans cooler to help keep it cool. i have a 2400rpm stall in my bronco, and with the stock cooler, it would peg the trans temp gauge (280 degrees) in less than two minutes with heavy-throttle wheelin'. cruise temp was around the 200 point.. and i tried towing with it too.. pegged the gauge as soon as i hit a slight incline. i was even careful to keep it in lower gears so i was well above the stall point
