engineeering
- July 3, 2014
- 06 explorer xlt 4x4
I don't think color coded helped lol but I do know you need only 8 wires 2 for the motor 1 for the clutch and 5 for the sensor now on the 97 you will notice 1-5 and on 06 1-4 with sens return one of the 1-5 from the 97 is the sens return it's either the 1 or 5 looking at both diagrams that will be the guessing game but the rest is straight foward the green sens return you highlighted green and crossed out and un crossed out is for the speed sensor return do not use that.
Tom
Hi Tom. Thanks for the quote above. That was exactly what I was thinking. But after looking closer... I couldnt figure out why the 06 EX had 9 wires (not 8)?. As it turns out... if you look at the diagram again... there is a clutch wire and a clutch position wire (the violet/orange wire). This is the clutch POS RTN wire... that's the one I highlighted green and drew an arrow to (Note that in my excitement when I figured it out... I forgot to update the other page I scanned on the left which should not show the clutch position wire from the 06 ex go to "blk/ground", rather, it should go to Gry/Red on the 01 ex tcase
Violet/Orange (on 06 EX) ====> (goes to) ====> Grey/Red (on 01 EX tcase)
If I'm right (could still be wrong. LOL), I believe the speed sensor return wire is the other grey/red wire. There are actually 2 grey/red signal wires coming from the 01 EX tcase (1 from clutch... the other from the obsolette speed sensor).
on another note.... I did ultimately loose my speedo. Turns out the ABS system does operate my speed... however,... the abs system also reads the output speed sensor from the original auto transmission. For this reason... I can ether use my new tcase output speed sensor (the extra grey/red wire) OR the output speed sensor in my new MO5D-h1 transmisison. Either way... I will just need to adjust my tune depending on how many holes the shaft sensor reads (the stock Auto Trans speed sensor reads 24 on the tune... I've read that the Mo5D has 12... If I don't change it... my truck will read double the speed)
Anyways... I'll wire it up tomorrow or when I get back from Mexico. We'll see if she works
