Betty's "I want to be a mule" progress log thread | Page 75 | Ford Explorer Forums
i was just about to message you to see if they came or not. are they also the right color or very close to it?
and your welcome as well.
so that every one wants to hear a funny story. i saw jon's post he needed these parts. i have a 96 that has a tan interior but wasnt sure the shade would be right. i also work at a scrap yard and they buy vehicles for scrap. either the day of or after messaging jon i happen to spot a explorer coming in. they dont come in as much anymore (to be truthful the last one i saw come in was a white 2000 limited 5L i bought sold, then bough back and resold then it ended up where i work). i had a loader put it aside for me and when i went to look at it, it was a 2000 with a tan interior. hows that for luck!
Still can't thank @vroomzoomboom enough. Tim, if you ever come by I'll make pancakes!
Finally got the dome light working. Silly LEDs are a 50-50 shot whether you gotta take it all down again and flip the reversed ones. Spine must be really messed up because that overhead job was making me want to roll the whole truck over.
Got the overhead console out now. All the copper foils for the map lights pulled loose. I spent about 2 hours straightening them all up, glued em back in place with liquid tape, only to discover the twist wedge sockets are too far gone from heat damage.
I'd like to find a way to solder 2 small quantum (?) boards in there. Possible?
no biggie and your welcome. trust me, i am down for a road trip right now however evils down for the count at the moment, and winter is coming.
I was able to not take pictures while using soldering iron to remove material in map light bulb hole area, and, "plastic welded " , um,sort of , 2 led board things in place, then, direct wired them into the overhead console connector.
Today, Betty gave me another surprise.
Instead of dead display, she's giving it all
I think the "METAL" might be for cassette tapes that were called metal in the description. I had a case of Maxell M90 tapes that were from just before CD's came out.
Rush, Tom Sawyer, that's the blast it full volume I think of song;
You know it's cranked up too loud when the amp clips off sometimes. I pushed my little 30w x2 amp(PA200) hard back then.
for me its either travelin band (CCR) or black betty (ram jam)
dont usually listen to stuff loud, just like clarity, but sometimes volume is nice :D
Just replaced Betty's 7 year old Walmart Maxx battery with a new one. You gotta admit that was a good run on it, so, it got another.
7 years is an almost unheard of run! When I worked a counter at NAPA 4 years was good (I discovered quickly that, although I thought cold KS winters was hard on batteries, nothing can kill em like AZ heat!).
I stretched the 7 years a bit. Tag on battery was 10-2016 manufacture date. So, 6.5 is more accurate. Still good though considering where she's been in that time.
Today's PSA is:
Never go against your own advice.
Yesterday was the start of going backwards to follow my own.
Way back when the new engine went in, with the help of countless forum members for a whole weekend, I prepped the motor with new gaskets.
I used the silicone rubber china wall gaskets!! Can you believe that? I say never do that and did it anyway just because the factory gaskets sealed so we'll.
Betty has been a skeeter killer ever since. Oil leaking onto the bell housing and dripping onto the cat shield. Once it's happening, it only gets worse so instead of burning down whichever building she parks close to, let's fix it.
Lemme tell ya. Getting old sucks. I used to coulda did this myself but man, it has been a fight just to get the upper plenum pulled. Egr tube would not surrender so sawzall fixed that. Once a socket would fit, my Ryobi impact zipped the useless nuts off manifold fitting and egr valve( valve in vice as not to crack elbow) .
I've only broken 3 injector connectors so far. Only tried unplugging 3 so I ordered a new egr tube and 8 injector clippys.
Valve covers also leaking. I have new intake set, and fel pro blue rubber to go back in.
If there are better intake and valve cover gaskets to get please tell meow. Not to sound like a kitty, but I really don't want to do this again. I already know I will not be able to place the intake or upper plenum on my own. I almost gave up trying to get upper off. So many things plugged in underneath, and my spine just will not allow all that holding and pulling crap . I can get help though.
Situation seems normal to me. :-(
It's so tight in the engine bay, its crazy.
Hate to actually admit this, but I'm so happy Tim was able to make something out of the pile of great parts I had.
I'm still happy to have washed my hands of the continual missery I endured. Self inflicted, but still..................
You brought back very painful memories. Hang in there Jon.
Let it leak, you always have fresh oil in that way. 🤪
I like that option but it's getting worse. Neighbor had a magnum V8 Durango go up in flames in his driveway for same thing though.
Well now you have me worried. I've got an oil pan gasket and a rear main seal leaking that I've been ignoring for a while because I just don't want to do the work involved in fixing them. Besides, as you noted, they leak onto the catalytic converter heat shield and the oil gets cooked off before it even hits the ground. But if its gonna cause Eddie to go up in flames...
Don't Google search it then.
Anyone reading, if an under hood fire does happen to you, and you can get hood release to pop, spray the safety latch with your fire extinguisher to cool it. It's gone be sizzling hot. Wish we'd known that before .
In that case panic took over and we emptied 2 under the Durango. Had to wait and watch for fire dept.
@traveler , check how high up the bell housing oil is present. You could have a leaky egr grommet, or even valve cover. Inside my bell housing is dry, if yours is dry behind the inspection cover, your leak is higher up. Fingers crossed for you.
