Betty's "I want to be a mule" progress log thread | Page 77 | Ford Explorer Forums
Outta the blue, and into the black
That looks very nice!
Woot!
Got the upper on and bolts in on first try! Myself.
Split a 1 3/4 " long chunk of 1/4 " hose to use as rear upper bolt holder. Place gasket by lifting, then use the rear holes as gasket targets. Make sure to plug in new pcv first, then all vacuum lines. Now you can do the gasket.
Might not sound like much but that means I didn't mess up a gasket.
I
All hooked up, R/O water to fill flush, 3 turns of key to prime and Betty fired right up.
I found several small unmetered air leaks doing this work also. Biggy was oil breather line into air intake. I used a screw clamp to tighten that.
Other small air leaks evident at throttle body gaskets, and egr gasket.
All new this session
Injector o rings, injector connectors, all coolant hoses, tensioner and idler pulleys, throttle body and elbow gaskets, egr gasket, lower intake gasket, pcv valve and hoses, valve cover gaskets, and got rid of the blue
Except for the dang timing cover . Oh gravel in my coffee
Tried k seal , thought I bought time but nope.
I'm not going to second guess, new cover , gaskets, bolts and rtv coming via Amazon.
Teardown begins on 3
1, 2
They get easier
I use robo grips to squeeze the tabs
I put the v6 setup in whenever I get a chance
1, 2
I hope it goes better for you this next time Jon. I put mine off when I bought my latest, it had a minor leak at the timing cover. I got through Winter, but in late March the stop leaks(Bar's Leak Copper seal, and K-Seal) weren't helping much.
The prior owner had changed the WP, so the bolts let go easily. But the timing cover they evidently disturbed when they loosened all those bolts, and the gasket seeped at the left coolant passage. I spent plenty of time cleaning the surfaces around the timing cover and oil pan etc. With Ultra Black in the corners, anti-seize on the bolts, plus the gasket Spray a Gasket, it hasn't leaked in two years. Take your time and do it well.
I water hosed my radiator for several minutes to remove as much of the stop leak as possible. I have a minor leak at the lower radiator hose(screw clamp), popping the cap shows a tiny amount of sludge build up on the cap. So it's not easy to clean the system. I drained my system after it was assembled and filled, twice. These have excellent cooling systems, except for the awful radiator mounting of the condenser.
It's the small square tab on the bottom driver side corner.
Thanks Don for the advice. Parts won't be here till Thursday so I have lots of time.
Slightly intimidated by the timing cover bolts. They like to break off .
I still have a hard time understanding why no one ever made replacement bolts, besides Ford. They obsoleted them in about 2009 IIRC, I tried once in that year range to buy spares.
I took notes in 2021 when I did my timing cover etc, wrote down the original bolt lengths. At that time ARP still didn't have any bolt kits which matched the needed lengths, only about half of their kits had useful bolts. I have two or three of those kits, I managed to save all but two of my old bolts. One was a bad replacement(wrong threads and length but they screwed it in), and one as too short(1/8" of threads). So I replaced two with generic grade 5 bolts, not perfect but close to the right lengths.
The lengths are wild, there are several different lengths, many 1/4" increments from 1/2" dimensions. To do it properly, the holes should be all measured anew, compared with the OEM, and new lengths chosen. Then ask ARP if they have those specific lengths, obviously without stud threads of course.
All timing cover bolts out, including the oil pan to cover bolts, 4 of em.
I must be missing something. Got a wiggly cover but it isn't wanting to let go.
