CHIEF Is Almost a 302!!!!!! 91 XLT SAS In the process of 302 and T-5 Swap!! | Page 3 | Ford Explorer Forums - Serious Explorations
Hello Everyone!
It's Chief here, Aka: Tim. I started with this pitifull excuse of a motor called a V6 and even more of a dissapointment This POS A4LD tranny! This will all be a nightmare that ended real soon:D
there we go!!!
There it is!!!!
Damn that looks gooooood
SWEEET!!!
starin up the rear....
This pic shows how the motor is a little crooked side to side. It measures out about 3/4 of an inch ****ed towards the passenger side. I'll fix it tomorrow!
The center should be at 12" not 12 and 3/4.
Here is one more from the front
I'm guessing you live in East County somewhere cause I know my neighbors in Scripps Ranch would die if I was using a bobcat to do a motor swap in the front yard. They're gonna die when I start the cage in my next project and bust out the chop saw all day for a couple weekends in a row!!!
heh, Nope, I live right in Clairemont. I would use a hoist but there isnt one that will pick high enough. Actually scripps ranch isnt far at all.
ok next things going on.....
1) I repositioned the motor. It looks right now.
2) I started working on the Ac condensor next. I want to mount the Ac condensor in front of the radiator to make room for the radiator to be tucked under the front support. A couple of things were neede to make this happen.
-First I had to cut off the hood release lever....(I will Reposition it later)
- Next thing for this was to "mock" up the ac condensor and see where to drill holes. I figured out where i wanted it. Then I re-bent the top mounts and marked, then drilled new holes for mounting purposes.
Next, I wanted to widen the area for my radiator so I heated and re-bent the tubes on the ac condensor. The inlet and exit tubes are now about 2 inches out further where the enter through the support toward the engine. This means 2 inches each giving me about 4 more inches in width on my new radiator. Here is a couple of pics of the newly bent tubes. Sorry i should have got a before but you could probably look at your own for a comparison. It was a dramatic difference and a pain in my ass to do it without damaging the condensor....
here is another .....
The next thing for this was a big one and that was to get a billet grill which freed up a lot of room behind it for the Ac condensor....
here is another from the side. It is gonna look great with new clear corners!!
one more from the front....
Next was to widen the area under the front support for the new radiator so I spent about 3 hours today grinding the hell out of my front support to get more room under there for a custom radiator. here is a pic before I started........
here is one while I cut this piece off......
here is one after I finished, well I am not quite done but its close, Anyway there is a lot more room!
here is a look from behind before.....
here is a shot from behind after I cut it out.....
