- December 22, 2021
- Los Angeles, CA
- 1998 XLT 4x4
24 Rngr 4x4
having sat down and done some review for a math quiz, and thinking about exhaust, im wondering:
is backpressure vs pipe diameter, like nearly everything in life about the balance. if so, im wondering, is the optimal pipe diameter etc contingent on (focusing on torque here) about that equilibrium of max flow matching exhaust output at peak torque point. for example, say a motor has its max output at 3000, and at that rpm under WOT it displaces 5 CFM of air, would you need piping with a diameter that can support that same? i imagine the same is true for HP, just at high rpm it is pushing more air out, so it needs more diameter. the reason why it may lose torque with too wide pipes (say optimized for HP)im speculating may just be because when you blow out, the air does not just go straight, it kinda makes this form
and as such, with each "exhale" or exhaust valve opening, the air makes this form, and loses velocity, and the air coming up behind it form the next opening of valve causes it to be too slow and create a "backlog" of sorts, and areas of high & low pressure, as opposed to amore consistent rate of flow, so the engine doesn have to work harder. nto sure if that made any sense whatsoever, this is just some brainstorming while reviewing for math quiz
