Went back a re read
Almost seems like a slipping trans? You said trans pan temp got up to 190… that is pretty dang hot for a trans… I mean usually I see 180 in the pan when it’s hot normal operations 150 is more like it
Could be slipping converter causing rapid water temp rise on hill
However 212 degrees is within the coolant operating range, it’s not till 220-225 I start to worry. Coolant operating temp is usually 15-20 degrees above thermostat opening temp, ours are fully open at 198 (we hope) so 210-215 is still in “normal” operating range. I don’t like running at 215-220
But ford would tell you “within range”
Could be fan clutch, heard you mention that a bit
I had the catalyst inside one of my
Converters break loose years ago… all was fine until I get on a steep hill then it would fall to the back of the converter housing and plug on the exhaust… big loss of power, engine would heat up, took me a bit to sort that one out
